Can a 2010 Prius engine be swapped w/o removing the transmission?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by texaspartsman, Aug 11, 2015.
  1. Toffer
    Toffer Junior Member
    Yes you can remove just the engine from the top. In fact this is the easiest and most logical technique to use. Works for me. Just had to remove unbolt the water pump and swing it to the side without removing it's electrical plug. Also you will need to remove the crank pulley for extra clearance along with the motor mount on backside middle of motor. The rest is self explanatory.
