Can a British EVSE Cable be Used on an American Car?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenmce, Apr 21, 2014.
  1. mrbigh
    3,686
    699
    Long Island, NY
    Can NOT be used, in order to connect it to 240VAC, the EVSE will have to be modified to accept such a voltage.
    The company "EVSE Upgrade " is one solution.
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You can supply 50A and it won't matter. In fact, if it's a 10A device, you should put it on a minimum 15A circuit, not 10A. The EVSE will draw the current it wants. More specifically, the charger inside the car will draw the current it wants through the EVSE.
    What happens is that the car will communicate with the EVSE. The EVSE tells the car how much current the car can draw, and the car won't draw more than that amount. This includes voltage and amperage. The EVSE has internal protection circuitry in the event of an overload, but an overload won't occur.
  3. Rebound
    3,996
    2,644
    Portland, OR
    The device is labeled 100 - 240V, unlike the American 110V only units.
  4. mrbigh
    3,686
    699
    Long Island, NY
    The person asking the question included:
    " i gave 2012 plug in from USA with own cable. on this cable written:
    input voltage: 110-120V 12A
    output voltage: 110-120V 12A
    can i connect it in 220-230V soccet?
    Is it clear enough .....:barefoot:
  5. Rebound
    3,996
    2,644
    Portland, OR
    I'm sorry for the misunderstanding. This thread began with someone who wanted to use a 240V UK EVSE here in the USA. Then someone with a 120V-only EVSE wanted to use it at 240V, which will only work if the EVSE is substantially modified.
    #45 Rebound, Nov 28, 2016
  6. bisco
    51,955
    the solution will be to buy an L2 evse from someone online.
    Yea Right likes this.
