Can a Gen 4 prius run out of its hybrid battery in ignition on mode
Discussion in 'Gen 4 Prius Main Forum' started by Alkanator, Jul 18, 2021.
  1. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Yes, that is exactly the mode described on the Toyota Japan site.
    トヨタ アクア | 特長 | トヨタ自動車WEBサイト
    According to the description, you enter this "emergency power supply mode" by following those steps.
    1. Foot off the brake and push the power switch twice to enter ON mode.
    2. Make sure "READY" is not indicated, and push the AC100V switch 3 times. *Do not allow more than 1 second in between the 3 pushes.
    3. Confirm the display on MID that the "Emergency Power Supply Mode" has been enabled.
    4. Plug in an electric appliance to the onboard outlet. If the ground is needed, plug the gound wire into the "Earth" plug.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    interesting - but in Australia, we're all 240volt. Not sure if an inverter could be used?
  3. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If Toyota were to offer this inverter down under (or in Europe) it would produce 240v.
    JeffD
    alanclarkeau likes this.
  4. ChapmanF
    18,213
    If the frequency matched up, a simple transformer could be used, though at a 1.5 kVA power rating, it would be a bit heavy.
    The frequency used in the US is 60 Hz, but I think it's 50 Hz in Australia. That's harder to deal with; easiest to let Toyota equip the car for the right frequency and voltage.
