Can a Gen3 Harness for the Prolong Charging system be used for Gen2?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by suomynona, May 26, 2020.
  1. suomynona
    suomynona New Member
    utah
    I think I've seen some people say they've used the Gen3 harness to charge a Gen2 Prius. Anyone have a guide or tips or gotchas that one would need to know in order charge a Gen2 with a Gen3 harness safely?
  2. Prodigyplace
    12,488
    11,731
    Central Virginia
    If it could I am sure @jeff652 would not have made different versions. Since there are different harnesses I must believe there was a functional reason.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    The leads on a Gen3 hv battery are in a different place than on a Gen2, that's why the harness is different ;).
    If you will be charging outside of the car, this can be done, but ensure you have a fan blowing across the battery:).
    Otherwise I would buy the right harness for the battery and model when charging in the car(y).
    SFO and Prodigyplace like this.
