Can a Prius jump start a another Prius?
Discussion in 'Gen 3 Prius Main Forum' started by whiskers, Jul 1, 2019.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Think about it for a minute.
    There is a LONG cable from the battery to the jump points.
    It is a large enough gauge to support the minimum current needed to boot up the hybrid's computers and allow it to start.
    It likely is NOT heavy enough to support the hundred amps or so that is needed to run the conventional starter in a different vehicle.
    In this case, the direction of the current does make a difference.
    tvpierce likes this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Mind you, the cost of incorrect polarity rises to a Max of $8000. (some inverter units have field serviceable DC to DC converters, for 'only' $600 each)
  3. Patrick Wong
    18,210
    6,517
    The point of the logic is that with the Prius as the donor vehicle and a non-hybrid as the recipient vehicle, the current flow may exceed 100A in adverse conditions. That current flow would zap the 100A DC/DC fusible link if the Prius was READY; or possibly the 120A MAIN fuse in the battery positive terminal block.
    If you hook the jump cabling directly to the Prius 12V battery then no Prius fuses are in the picture if the Prius is IG-OFF.
    It would be better not to use the Prius as the donor vehicle to avoid these issues as well as the potential issue of zapping the inverter in the event of botched battery polarity.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. Mendel Leisk
    42,345
    Or just touch them both to a contiguous piece of steel...
  6. 2014
    2014 Member
    30
    31
    MA
    Another car, other than a Prius, needs considerable current to be jumped, hence the typical robust jumper cables. It may be that the path from the 12V battery in the rear to the exclusive jump starting terminal in the fuse box is not sufficient to carry the current draw to the vehicle that needs to be jumped. Direct from the 12V battery through large conductor jumper cables is probably a path of much less resistance.
  7. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    No kidding! This is about Prius-to-Prius jumps, though.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Can a Prius jump start another Prius?
    Well I think there is hidden camera footage of it happening in the wild. But I don't think it's ever happened in captivity.
    GrGramps, Ed Beaty and Mendel Leisk like this.
  9. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    I used a jumper pack last night. 12 Volt went from "No worries!" at my house to flat dead five minutes later. My jumper pack got ME home. All I had to do was climb through the back to access the pack which was stored back there) and the 12 volt battery. I just left the little cover over the hatch latch off. Fact is, I tossed it.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Prius safety measures are suggestions, just like the prius operating manual. No one reads that.
