Can anyone explain this behavior?
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Jan 29, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I can't believe I wrote webcam, when I meant dashcam.
  2. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If I had to guess, I'd say the salt in the water was somehow making the RFID work from the key fob to the door sensor, even from 2 m away.
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    You are correct. I had a Gen 3 (2010 IV) and the fob didn't have that function.
  4. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The sensors in the door handles work by sensing the water in your hands. I believe they use a local magnetic field that is calibrated to detect changes when significant water is nearby(like within a few centimeters). When you wash the car, it can trick the sensor into thinking your hand is near the handle. These sensors are separate from the keyfob sensors.
    The keyfob sensors detect when the fob approaches the vehicle and begins to wake it up. It also activates the magnetic sensors. When your hand enters the magnetic field while the keyfob is within range, that's what locks/unlocks the door. I believe the magnetic sensors are turned off either when the fob enters the vehicle or when the power button is pressed so the system can't be triggered in a massive downpour.
    Personally, I just ignore the locking/unlocking when washing my car. If it really bothers you, just move the fob outside the range of the car until you finish the wash.
