Can anyone help me? My 2010 lit up codes P0A93, P0C73, P314A
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Trachuk, Jul 3, 2024 at 8:56 PM.
  1. Daniel Trachuk
    Daniel Trachuk New Member
    Wednesday
    Portland OR
    those are the codes that lit up on my Prius. I bought this Prius several months ago off auction and ended up replacing the front end with a nose cut. Wanted to see if anyone had similar codes and what you did to configure the problem?
    49,397
    are you sure about that first one? what code reader are you using?
    49,397
  4. Daniel Trachuk
    Wednesday
    Portland OR
    Oops, I meant P0A93
  5. Brian1954
    Brian1954 Active Member
    797
    300
    South Central PA, USA
    I am guessing the first code should be P0A93.
  6. Mendel Leisk
    38,653
    What’s the miles?
  7. Daniel Trachuk
    Wednesday
    Portland OR
    Prius has 111,000 miles
  8. Tideland Prius
    16,128
