Can anyone help these codes please: PO420, P3000, C1259, C1310
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Funkyfem, Jun 4, 2018.
  1. Funkyfem
    Funkyfem Junior Member
    Hercules, CA
    I'm wondering if someone can help me with these codes. Big O looked at the car and they say I need a catalytic converter. Apparently it's common with a car that has 227k miles on it. Looks like one or two of the cells is bad on a refurbished battery. I'm going to replace the battery with another "recycled" with new cells cost $400. Does anyone have any recommendations for a cheaper catalytic converter that will ship to CA. I checked Ebay and apparently most don't. Is this a tough job to replace it? Big O says it'll take 15 minutes. Big O also says the part is $1800 from Toyota. Uh, no. I would appreciate any help. THANK YOU in advance.
    52,041
    afaik, you have to use oem in cali. maybe time to look for a younger vehicle?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Since your in the Bay Area, one place I would check out is the auto recyclers about 45 miles away from you in Rancho Cordova ;).
    I bet they have some catalytic converters for sale on some of their wrecked stock:).
    Do you have Techstream? If so, it makes narrowing the battery issues down a bit easier ;).
    Good luck and keep us posted (y).
  4. Funkyfem
    Hercules, CA
    Thanks for your response. I figured it out. I replaced the battery and it fixed the problem. It was a recycled batter with new cells. It seemed to do the trick. I don't want to get rid of my car! She's got 229,000 and runs well. My last Toyota I got 375k original miles on her...that's the plan with this one.
  5. Funkyfem
    Hercules, CA
  6. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Do you mind sharing more details:
    • Did you buy one from a shop?
    • A mobile repair outfit?
    • Do it yourself?
    • Does it have any warranty?
    • Willing to share the price?
    Data helps us and other members who are in the same spot ;).
    Keep us posted (y).
  7. Funkyfem
    Hercules, CA
    Absolutely! No, I did not buy the battery from a shop. I found a guy on CL who specializes in removing the old cells and replacing them with new ones. He has a 6 month warranty on his work. I bought the car from a couple who didn't want to buy a new battery so the car sat for months. I called the mobile battery guy he removed the battery and the car started immediately. I paid $500 for him to drive to the car and replace it which took a total of an hour. I was amazed that the car ran perfectly. I haven't had any problems for the last 2 years until now. I called my guy towed the car to his house and again he replaced the battery in an hour. This time as a repeat customer he charged me $400. The new battery cleared all of the codes that came up when the main battery failed. After driving the car for 100 or so miles I had to Smog my car for registration renewal. I guess there was no problem with the catalytic converter because it passed with flying colors. The call has high miles and purrs like a kitten. I have had zero problems with it.
    BTW, my old FOB is falling apart. I bought a used on from a prius junk yard dealer. I did the chicken dance on it found on Youtube and it actually worked. The only problem is that it does not unlock or lock the car. I hope this helps. Thank you.
    • Do it yourself?
    Keep us posted (y).[/QUOTE]
  8. bisco
    52,041
    well done, all the best!(y)
    Funkyfem likes this.
