Can anyone school me on Hypermiling?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by priusmouse, Jan 5, 2023.
  1. priusmouse
    priusmouse Member
    255
    85
    Long Island, NY
    2023 Prius
    I've been driving a Prius (2017) for a long time but never bothered trying to up my milage. With my '23 on the way my new year's resolution is to get the best MPG possible out of it ;P
    How do I do this hypermiling stuff?
    I know not to carry unnecessary weight and avoid messing with the aerodynamics with roof racks etc. But how should it be driven to get the best milage? And does idling with the heat/AC/radio on in Park really reduce milage that much?
    McCarthy likes this.
  2. Mendel Leisk
    42,314
    What do you think, sitting, with the engine cycling on and off, burning gas, but not getting anywhere?
    Some tips, both for improving mpg, and reducing your driving needs (both of which save gas):
    1. Never just sit with the engine running. That basically zero miles per gallon.
    2. Obey speed limits. The faster you go, the lousier your mpg. Too, if you're speeding, next stage is lane jumping, tailgating, and so on.
    3. Maintain a good following distance. This allows you a buffer when slow downs occur, you can often avoid braking, which squanders momentum.
    4. Consolidate trips. Avoid short trips. Consider alternatives, say walking, for nearby errands. Sometimes if you got several destinations, but they're all close to each other, consider just parking somewhere central, walking from one place to another.
    5. Park under cover. In winter this'll avoid fogged/frosted windshields, avoid a lot of #1.
    6. Consider installing a block heater, and using it regularly.
    7. Be diligent about maintenance, engine, brakes, battery and so on.
    8. When the car's partially warmed in particular, try turning the H/V system right off at red lights, and/or turning the cabin temp down. Reducing cabin heat demands will often tip the car's computers to turn the engine off, sooner.
    9. Use AC sparingly, set the temp as high as comfortable, and just don't use it for short trips or in moderate weather.
    10. When parking in near-full parking lots, go to the back corner where spaces are more available, versus circling round and round closer to store/venue.
    #2 Mendel Leisk, Jan 5, 2023
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Accelerate like there's an egg under the pedal.
    Brake like there's an egg under the pedal (you shouldn't feel seatbelt pressure on your chest).
    EV under 50ish mph, HV over (PHEV's).
    Kasra likes this.
    52,817
    accelerate briskly to something above speed limit, then hold neutral to something below limit, rinse and repeat
  5. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Let your foot off the gas pedal plenty of time before actually needing to brake.
    Tightwad77 likes this.
  6. fuzzy1
    10,694
    Trollbait likes this.
  7. billvon
    billvon Junior Member
    32
    17
    That works with most cars, because it reduces pumping losses. However, with a Prius, the Atkinson cycle engine reduces them already, and the hybrid system will actively be working to counteract you doing that by providing battery power when you accelerate.
    With a Prius the things that still work are;
    1. Driving slower
    2. Drafting (dangerous and annoying of course)
    3. Not idling for significant amounts of time (note that the engine shuts down during short "idles" so no worries there)
    4. Not letting the car warm up for 15 minutes before driving
    5. Braking gently so as to use regen as much as possible
    priusmouse likes this.
  8. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    If the car behind you is honking their horn, you're hypermiling correctly... :D
    Sharol, Markel, Wes_33073 and 2 others like this.
  9. Leadfoot J. McCoalroller
    8,279
    7,791
    Pennsylvania
    2018 Prius c
    ^ that.
    You should be aware that it is a relatively antisocial driving pattern, best employed on test tracks or waaaaay out in bfe where there's no traffic.
    GeoJ and Hanging on with 286k like this.
  10. Trollbait
    12,818
    If your situational aware, and should be for safety, hypermiling can be done.
  11. Mendel Leisk
    42,314
    Stealth hypermiling. (y)
    fuzzy1 likes this.
  12. Leadfoot J. McCoalroller
    8,279
    7,791
    Pennsylvania
    2018 Prius c
    Not saying it can't be done- heck, I knew a guy who could double-clutch shift an old truck while making a left turn in Boston traffic while he was rolling a cigarette with his left hand.
    And I agree, situational awareness is the key. But it's also one of those things where you might be the last to find out you didn't have enough.
    Recognize the risk, be careful & maybe save a few bucks.
  13. billvon
    32
    17
    Absolutely. But like the post above said, it's still antisocial.
  14. Mendel Leisk
    42,314
    There's no satisfying some people on the road; if you're in front of them they go nuts. It's their nature. Once they get by you, the cycle begins afresh, with whoever's next in front of them. I'm not sure what happens when they're on an empty road.
  15. Leadfoot J. McCoalroller
    8,279
    7,791
    Pennsylvania
    2018 Prius c
    Radar cruise completely fixed that for me. Makes highway driving way more relaxing and also saves fuel vs. the foot.
    Probably doesn't save as much as active, concentrated hypermiling but for me the point was to hop in and go, not think about that stuff and rely on the car's whizzbangness to show me savings anyway.
    It's been working great.
    Although our Prius doesn't have radar cruise, regular cruise helps a lot. The radar system on our other car is fantastic.
    Bill Norton and Mendel Leisk like this.
  16. Mendel Leisk
    42,314
    Yeah guess you could have a radar cruise convoy.
  17. bisco
    52,817
    when on an empty road, they drive the speed limit. they only accelerate when they spot a vehicle ahead. something satisfying about catching up to and, and trying to come as close as possible without touching
    samsprius1, McCarthy and Mendel Leisk like this.
  18. bisco
    52,817
    then driving the speed limit must be antisocial, because it engenders the same behavior
  19. Trollbait
    12,818
    If my driving still allows you to drive as you wish and keep up with the rest of traffic, how is it antisocial?
    MTN and fuzzy1 like this.
  20. billvon
    32
    17
    If everyone else is driving 30mph above it - yes, it is. (And fairly hazardous to boot.) That's rarely true around here, though.
