can barely hear turn signal clicker
Discussion in 'Gen 3 Prius Main Forum' started by anniea, Jul 15, 2009.
  1. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    Easy to buy either one 12 volt buzzer and two diodes, or two buzzers ($3 each at Frys).
    Accessing the wiring might be a bit more work.
    Does somebody have an illustrated "how to"?
    Is the Turn-Signal relay located in a some easily-accessed place?
    I would prefer lower-frequency buzzers, so I (with substantial high-frequency hearing loss) can hear them better.
  2. benh57
    benh57 Junior Member
    Westchester, CA
    I am very sensitive to small noises and I like the quiet blinker noises.
  3. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Drove the car for the first in 6 weeks, I was blnded by the flashing :cool: :p, and when I turn the radio down I could hear it :D
  4. gandG
    gandG New Member
    28
  5. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I like the way it is, quiet.
  6. bisco
    52,824
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Had the same problem in several cars. Checked my hearing. Now, 2 hearing aids later, it is easily heard. Don't know if that is your problem, but hearing loss sneaks up on you so gradually, you'll swear your hearing is fine...till you get tested, and you won't believe the difference.
