Can extreme heat cause my Prius C to act odd?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Cable387, Jun 29, 2013.
  1. needtongo
    needtongo New Member
    I'm a newbie when it comes to the Prius C, but whereabouts are the vents located exactly?
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    In front of the rear seat, seat bottom on the left. Just behind the drivers seat. It's on the upright wall
    under the front of the seat and above the footwell :cool:
    minkus and needtongo like this.
  3. rfruth
    rfruth Member
    394
    Houston, Tx
    Is there a fan to help cool the high voltage battery, if so does this cooling fan continue to run even after the car is off ? (again if so the 12v battery must get a real workout)
    51,882
    there is a variable speed cooling fan, if it runs after you shut the car off, it's probably powered by the hv battery it's cooling.
  5. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    There is a fan (hence the vent under the seat) and it does shut off when you turn the car off. You should be able to hear it.
  6. needtongo
    Found it! Thanks Drdiesel. Do the vents ever require any maintenance?
  7. Drdiesel
    585
    152
    Monterey CA
    I'm sure it would, but not very much unless you leave the windows down and follow trucks on dirt roads.
    Maybe about once a year you could pull the panels and clean the dust out. Otherwise it's pretty fool proof.
  8. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    I've never been able to hear the fan, though I've never gone back there to look/listen when the car's been running. I do stick my hand back there from time to time to feel the air movement, though.
