Can fully bottom grill block in 60F weather.
Discussion in 'Gen 3 Prius Main Forum' started by Higgins909, Jan 13, 2025.
  1. Higgins909
    Higgins909 Member
    289
    71
    Thermostat arrived. Still planning to install Friday night. But these last 2 morning, it's been about 48F. My heater seems to be working now or something. Maybe it's just warmer? So I press auto and set the temp to 80-high. It goes to floor vent, fresh air, fan 0-1 bar. However if I put it on face or face and feet, it turns the blower on about 5 bars. In about 5 minutes it starts blowing warm air, which that part is normal.
    I thought normally no mater what vent I selected, it wouldn't turn the blower on until the engine was warm enough. When on auto. I haven't had my scangauge 2 plugged in for about a week now, so I have no idea what temp it was. I had previously been using face and feet, but it seems like face warms up so much more? Idk, I'm not explaining it the best and it doesn't make sense to me right now.
    I still plan to change it, because even when it's 90F out, I think my coolant temp barely hits 160-170F on my 20min~ 7 mile drive to work. Going to either figure out it's normal or something was wrong with it. As far as I know, it's the original.
    Prodigyplace likes this.
  2. Higgins909
    Higgins909 Member
    289
    71
    Looks like it's probably been stuck open since 2020 in the least. Only did a short drive. But it seems like night and day. I took out my grill block because I had to drive to Autozone to get more coolant. 61F outside. Got to 160F in a couple minutes. Seems to be holding that to 180F pretty easily now. Just driving a tiny bit.
    Nearly got taken out on my way home from Autozone. Was doing about 45mph in a 50 and someone pulled out in front of me. ABS didn't seem right. Like it went off but I thought I barely braked and didn't feel any sliding.
    New and old thermostat look quite different. The old is the metal piece is deeper. The coil also looked looser. Not sure if it slides on that black plastic or what. On the new one, I could see daylight through the little coolant hose part. Not on the old one. Gasket stuck to the engine. Had to scrape off garbage with a razor blade. Carefully. Including my trip to and from Autozone, took me about 2 hours. Getting both clamps back on was supper difficult.
    BiomedO1 and Prodigyplace like this.
  3. Higgins909
    Higgins909 Member
    289
    71
    Car way ahead of me didn't have any lights on. What I was talking about after "Nice" for the truck switching lanes late. 196F water temp. The highest I seen. If you watched it on repeat, when I brake, I guess I did brake pretty hard? Dashcam has been acting up with wanting to format the SD card, so I wasn't sure if it was caught.
  4. BiomedO1
    BiomedO1 Senior Member
    4,636
    2,434
    Left Coast
    Mileage may improve a little bit because with a warmer engine - mixture may be leaned out even further.
    FWIW; seeing a lot more drivers w/o headlamps ON w/newer cars. I'm thinking they're not used to the DRL and think their headlights are already on or they 'think' they have automatic headlamps. That's what happens when people don't pay attention and don't read their operations manual.
    I worked an early morning shift and seem to be flashing people at least twice a week now-a-days. It's still pitch black, not dawn. No marker or tail lamps, just the faint glow of DRL in front of their car.
    #24 BiomedO1, Jan 18, 2025
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    DOR??
    What is Driving Under Restraint (DUR)? - Mark S. Rubinstein, P.C.
  6. Mendel Leisk
    42,368
    LIkely misspelled acronym Daytime Running LIghts.
    'Round here DRL's are "mandatory", and yet you lose count of late model cars, with BC plates, and no DLR. We used to have mandatory annual roadworthy testing. That was shut down, and some of those stations repurposed to do emissions testing. That's shut down now as well.
  7. Prodigyplace
    12,720
    11,852
    Central Virginia
    We still have annual inspections here in Virginia.
  8. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Why would you fully block the radiator? If you leave a gap, the electric fan can circulate air as needed.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    I did that once in a vehicle with a stuck thermostat in a snowstorm. I needed to keep driving and the engine needed the heat.
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I installed a cardboard ahead of my radiator in my Gen 3 to make it warmer inside when it got really cold. I ended up leaving it in all year, and it worked great.
    People make the mistake of not leaving a gap, and their coolant boils out.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    After I got to our destination I had the thermostat replaced. Of course, this happened during a 650 mile trip :(
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm not a fan of replacing parts until it works again.
  13. Prodigyplace
    12,720
    11,852
    Central Virginia
    The engine was running cold in a lowing show storm in PA mountains. After we got to our destination we got it repaired. What made you think we were just replacing parts willy nilly? BTW this was a 1979 Dodge Ramcharger Utility truck 8 cylinder, not a hybrid. I guess you could say it was the Grand Pappy of the SUV LOL.
  14. Mendel Leisk
    42,368
    Even in summer? You're using the AC?
  15. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Never a problem in summer. I use AC all summer.
    Remember the gap.
  16. Mendel Leisk
    42,368
    I can't imagine doing that. :confused:
  17. ASRDogman
    ASRDogman Senior Member
    8,069
    4,091
    :eek::confused: Wow, I thought this was PRIUS Chat!
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    *I* thought we were discussing grille & radiator blocking. ;)
    I am a former Prius owner but I guess I need to take my 2025 Camry (hybrid) & leave?
  19. ASRDogman
    8,069
    4,091
    You missed including this part.... "
    Prodigyplace said:
    ....... BTW this was a 1979 Dodge Ramcharger Utility truck 8 cylinder, not a hybrid......."
  20. Higgins909
    Higgins909 Member
    289
    71
    I'm hoping for a slight MPG boost as well.
    I'm not a fan of DRLs. They should have never been "invented". Should have just regulated marker/parking/driving lights.
    It seems my thermostat was stuck open and has been for years. Every time it got 60F or less, I would start grill blocking the bottom grill. Eventually to 100%. The upper grill, I leave alone. The heat would absolutely struggle and kill mpg from the engine being constantly on. I'd even drive in B mode, to keep the engine on more, for the heat. But that killed MPG even more.
    Seem when in Auto air conditioning mode, it will turn on the heat around 103F engine coolant temp. It will blow warm at 130F but around 190 is when it blows hot.
    BiomedO1 likes this.
