Can fully bottom grill block in 60F weather.
Discussion in 'Gen 3 Prius Main Forum' started by Higgins909, Jan 13, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    One of the first things I did when I received my Prius about a year ago, was to install a sheet of cardboard ahead of the radiator. There is a structural member there that keeps the cardboard several inches away from the radiator. It required me to remove a top panel to be able to access the space. I left it in place all year, with temperatures up to 30C, and I didn't notice any decrease in fuel economy, but it certainly made it more comfortable inside during cold weather.
    Higgins909 likes this.
  2. Mendel Leisk
    42,323
    Your AC must struggle. You’ve covered it’s heat dissipating radiator (aka condenser). Not to mention the engine/inverter radiators. I can see a partial block in winter, but this doesn’t make sense.
    Anyway, I’ve said my piece, letting go.
    #42 Mendel Leisk, Jan 18, 2025
  3. Higgins909
    Higgins909 Member
    289
    71
    Yeah, in the middle of summer, it seems a bit extreme. But 30C really isn't that hot. (86F?) Maybe it fit's Paul's driving style.
    Once it's reliably in the 80F+ I'll fully take off my grill block. 80F weather is where my Prius seems to be very happy. Not really using either heat or AC at all. Getting "great" MPG.
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    You may have a point; I run my A/C in ECO mode most of the time, which I believe is 50% of normal.
    There was a hot spell last summer when it seemed to be inadequate, so I created a custom driving mode profile, which had all the same settings as ECO, except it ran the A/C at full capacity. I only had to use that setting a few times.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Wait a minute,
    What if the user doesn’t use AC at all?! I block 100% on lower grill during summer morning errands and don’t run AC.
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If I wanted to overthink it, I'd have probably taken the cardboard out, but I saw no problems from leaving it in.
  7. Prodigyplace
    12,711
    11,848
    Central Virginia
    I thought all Gen 4 and newer Prius had active grille shutters. Were they removed from later models?
