Can Gen2 & Gen3 cell be combined to rebuild a Gen1 pack?
Discussion in 'Generation 1 Prius Discussion' started by vaughnstark777, Nov 21, 2014.
  1. vaughnstark777
    185
    33
    Roy, WA
    2001 Prius
    I
    I've never seen Gen3 modules up close so I just want to make sure they are the same as the Gen2 modules.
    thanks
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    They are the same
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    They are the same except for there internal resistance. Mixing the modules is not a good idea as the voltage drop across the gen2 modules under load will give them a higher voltage drop than the gen3 modules. This could trigger a DTC for battery module voltage. The only way I can see round this is to use 1 gen2 module with 1 gen3 module for every module pair.
    John (Britprius)
  4. ChapmanF
    18,195
    How big is the resistance difference?
    -Chap
