Can God be Found By Science?
Discussion in 'Fred's House of Pancakes' started by airportkid, Oct 3, 2011.
  1. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
  2. daniel
    14,487
    1,519
    Spokane, WA
    Your definition is a valid one, however, it is not the only valid one. The issue is that "living" is a term that has defied concise definition. It was easy before microscopes. A mouse is alive. A rock is not. But the more we learn about nature, the less confident we can be as we try to draw a line between living and nonliving. I suspect that there will always be a grey area that might perhaps be better left unspecified.
    In mathematics a double negative equals a positive, but in language that is often not the case. In French, for example, specifying a negative may require two negative terms.
    "Nothing that does not exist can be found by science" is NOT the same as "Everything that does exist can be found by science." Language does not obey the laws of mathematics.
  3. Feri
    Feri Active Member
    761
    144
    Nothing that's non-existant can be found by science or any other method of discovery.
    Still a double negative? ;)
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That's what religion is for.
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    It isn't even true in Mathematics, just some cases. -10 + -3 =/= positive.
    In fact, you can state both "Nothing that does not exist can be found by science" and ""Everything that does exist can be found by science." in strictly mathematical terms. They are not equivalent.
