CAN HV BE CHARGED WITH A CAR CHARGER?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Sep 1, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    The Prolong is way better than trying to cobble up something. And it may be cheaper in the long run. I remember @jeff652 having a conversation with someone else in either Africa or the Middle East and saying they ship all over the world. Maybe he'll pop in here and refresh my memory.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Yeah, that's what I do.
    Always monitoring the batteries for temperature rises, and clamping the modules too
    jerrymildred likes this.
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I was the one that asked Jeff about tgr shipping thing yo Africa.
    It's do expensive for me right now
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Eric!!!??? Thanks so!!! Much. Would research on those.
  5. eman08
    eman08 Active Member
    360
    192
    US
    No. You need a grid charger power supply. That's like trying to use a cheap 10a battery charger to supply power to a 12 volt battery during ECU flashing which is too low of an amperage nor does it supply a steady voltage and amperage. ECU's pull a lot of amperage during ECU calibration, without a proper high amp battery maintainer you risk bricking the computer due to voltage drop.
