Can I adjust the headlight aim horizontally??? I.e left and right?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by graham hendren, Sep 15, 2015.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    My car just failed its mot . In the uk the offside beam is to far to the right . I have found the vertical adjust screw but can not see another . Nor have I seen anything on line about it . My car is a gen3 . 2010
  2. PRIUS STAR SHIP
    PRIUS STAR SHIP Junior Member
    34
    17
    Hope this is helpful.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    There is no horizontal axis adjustment. However, you should check that the bulbs are installed correctly in the headlight housing. With the limited access space available behind the headlights, it's very easy to incorrectly install the bulbs at an angle with the bulb tabs not fully engaged on all sides.
    This will cause the skewed light output you describe, but it can also cause damage to your plastic headlight housing if the heat from the incorrectly installed bulb melts the plastic mounting area.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    no is correct.
  5. xliderider
    8,140
    3,280
    Honolulu, HI
    Huh, you are not the OP... :confused:
  6. Jarkko
    Jarkko Junior Member
    36
    Finland
    2012 Prius+ MPV
    Old thread, but I failed to find anything on search too. Search at the car in good daylight brought some light to lateral/left-right adjustment.
    At least with LED head lights in my Prius+ (Prius v in North-America) there is adjustment screw. The light unit even contains instructions :) See attached picture: red arrow points to screw, and blue circle tells how to use it. IMG_1169.jpg
    The screw location could differ a little bit between models, but not much I guess..
