can i call what i'm experiencing an SUA, and other issues
Discussion in 'Gen 2 Prius Main Forum' started by nawlinsprius, Mar 18, 2010.
Do you have the same 3 issues?
Poll closed Mar 15, 2020.
  1. issue 1 - stationary SUA
    60.0%
  2. issue 2 - misaligned steering wheel
    20.0%
  3. issue 3 - gen2 ABS Brake weirdness
    60.0%
Multiple votes are allowed.
  1. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Thanks, Tom. I wasn't aware of that!
    After my previous post, I started thinking "Hmm, maybe you would have to actually put the Prius in neutral to get the rear (friction) brakes to activate and auto-adjust when traveling in reverse". But even this assumption would not have been correct. So thanks for correcting this.
    Those darn smart Toyota engineers.....they just about thought of everything when designing the G2! :)
    Best wishes,
    Frank
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Do they have a neck to grasp tightly? :) I think if I were mothballing, the car would be up on 4 jack stands.
    I ALWAYS use my parking brake when I am done driving. NEVER had a cable freeze and I live in Vermont. :
    1) Foot on brake to stop the car
    2) Press in parking brake
    3) Push and hold the Power button. This puts the car in Park and since the PB is already set, there is no 'roll' until the pawl and gear meet. If the PB is not engaged, the car WILL ROLL anywhere from a little to an amount that causes a noticeable jerk when the gear rolls against the pawl.
    4) Foot off the brake.
  3. richard schumacher
    7,664
    1,046
    United States
    Ditto that. *Always* use the parking brake: that keeps it from sticking and keeps the car from moving. If you apply it correctly you will not be able to drive away with it on. Make it habit, make it happen.
  4. Jolly English Gentleman
    Jolly English Gentleman Junior Member
    47
    Spalding, Lincolnshire, Uk
    I have no prior experience of automatic cars before owning a Prius, but on a manual, if you want to be stationary without any risk of moving, you would put the handbrake on after putting the gearbox into nuetral.
    The Prius is no different in my mind except that handbrake is on the floor. It nonetheless sounds like a handbrake and behaves like one. i.e when you want to stop permanently you put the car in nuetral, press P and put the parking brake on.
    Just think of the Parking Brake as handbrake on the floor. You would not park a manual car without the handbrake on would you?
  5. GasPort9
    GasPort9 New Member
    New York
    Issue 1 - The problem is you refusing to use the 'parking' brake.
    Issue 2 - Toe-in...have the toe-in adjusted with the steering wheel in the correct position....a simple tie rod adjustment.
    Issue 3 - Learn to adapt to the car you're driving.
    Issue 4 - Coasting in neutral....a bad habit in any vehicle.
  6. bisco
    51,906
    you realize this post is a year old.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    ...and it's off for another year!
    Tom
