Can I change the Speedometer Correct Factor?
Discussion in 'Gen 4 Prius Technical Discussion' started by ticedoff8, Jul 26, 2025.
  1. ticedoff8
    ticedoff8 Junior Member
    52
    San Jose
    I have a 2016 Prius Touring model with the digital speedometer.
    Is there a setting in any of the car's ECUs that I can change (and write) for "Speedometer Correct Factor"?
    Since I changed the tires, the speedo readout is about 4% lower than my phone's GPS says (Example: 55MPH speedo v. 53.5 on GPS. 77MPH on the speedo v. 74.5 on GPS).
    It's always been a little off even with the tires that came new with the car (I bought the car new from the dealer), but now it's bugging me.
    I have an OBDLink OBD2 adapter and their OBDLink app with its 2016 Prius enhanced package.
    From what I can tell, the app is getting speed from the tablet's GPS and not the ECU - it matches my phone's GPS reading and not the speedo readout.
    Or, is there a screen that I can look at on the car's LCD display that will do this?
  2. ticedoff8
    52
    San Jose
    Well, I can see this was beat to death on this other thread. But on a Gen3. I presume it's the same for a Gen4.
    If you sort through the "... it's a government conspiracy" posts, it comes down to "It can't be changed".
    I guess I'll just use my OBD2Link Bluetooth OBD2 adapter to my 7" Android tablet with the OBDLink app and mount it on the dashboard as a HUD to see what its GPS reads while I'm driving.
  3. Joe Dipierro
    Joe Dipierro Junior Member
    40
    SNJ
    My 2016 always reads about 2mpg slower when I use gps apps it drives me crazy
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    You can get a cheap GPS speedometer off of Amazon for about $15. Mine has a 3/4 inch bright display and plugs into a USB port.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Or a free phone app.
    No thanks.
  6. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    I don't want to leave my expensive phone on top of the dashboard of a hot car as thief bait.
    Even if you install the phone and program if for the speedometer ap every time you get in the car, and then remove the phone and take it with you every time you leave, that's a lot of time wasted and an endless hassle.
    The GPS speedometer never needs any attention or programming.
    It s automatically turns on and turns off.
    Almost no one knows what it is. Even if stolen, you'd lose only a measly $15.
    #6 Georgina Rudkus, Sep 27, 2025
  7. Mendel Leisk
    42,341
    To any and all, you could just keep in mind, with stock tires, that if the speedometer shows say 30 mph, you’re actually around 28~29 mph. Or just forget about it, accept that you’re going one or two blessed miles per hour slower than displayed?
  8. bisco
    52,841
    i run one or two over the posted limit. most drivers are 20-30 over, so it doesn't bother me or them.
  9. Priipriii
    Priipriii Member
    231
    67
    From what ive researched
    "Cheapest & most common fix right now (2025)
    Buy a Mini-VCI J2534 cable ($30–40 on eBay/Amazon) + Toyota Techstream software (free cracked version widely available) → change “tire circumference” or “revs per km” from ~1910 to ~1872. Takes 15 minutes once you watch a YouTube video. Works on every Prius ever made"
    Cant confirm as i never tried it myself but probably will in the future when i lift it. I know on other cars its much easier. On fords i use forscan a lot and its very simple to change tire rotations in the main computer of the car. I would imagine most brands allow you to do so too because its very important that the gearing system of a regular transmission is in the right gear for take off. But on a hybrid, that uses an electric motor for take off, theres really no need to change it besides the display of mph and miles for accuracy.
