Can I charge the Prius Plug-in with 110v
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by evebill8, Feb 24, 2012.
  1. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Hi folks,
    My circuit box is already max out. Not sure I can install the 220v charging station. Can I charge the Prius Plug-in with 110v? I don't mind to take longer to charge though.
  2. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yes, it would just take about 3 hours (versus ~1.5 at 220v)
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Toyota says "To ensure the vehicle charges correctly, your 120V outlet should be on a dedicated 15-amp (or more) circuit." Have you checked out the FAQ on the PiP website? It explains quite a bit about the car: http://www.toyota.com/prius-plug-in/
  4. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
  5. Trollbait
    12,818
    What is your home service, i.e. the amp rating of your main breaker? If it is only 60 to 100 amps, that is low for a modern house with all the gizmos we have these days. Then look into upgrading to a larger service and panel. Don't think of it as an extra cost for a car, but as investment into your home's value. Also use the time to install a whole house surge protector.
  6. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Level 1 charging:​
    Most home garages and yards have a standard 120-volt electrical outlet. In the EV world, this is known as a Level 1 charging outlet. Generally, a Prius Plug-in owner could use this type of outlet to recharge the batteries (assuming the circuit could safely handle the load), but a full charge would take about 2.5 to 3 hours. Owners who want faster charging should consider a Level 2 charger.​
    Level 2 charging:​
    In many cases, an owner with a garage or yard could arrange to install a special circuit and equipment to deliver a 240-volt current to the car, cutting the recharge time in half. So, with Level 2 charging, a Prius
    Plug-in could recharge in about 90 minutes. This drop in recharge time helps the vehicle fit better into an owner’s lifestyle and be ready when needed.​
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    A local electrician came out and checked my electrical box, breakers, etc and found that an existing outlet in the garage would easily handle the charging of my PiP.The existing outlet has only a sprinkler control box plugged into it, which draws only .1 amp.
    There was no charge for doing this, and he said if for any reason I needed to install a new, dedicated outlet, he would charge $150. But in my case, there is room in the box for whatever he would need to do. I think he mentioned using a double breaker in place of one already there. Maybe something like that would work for you.
    I would say the bottom line is call and ask an electrician to tell you what you need for charging at the 3 hour rate. My provider, So Cal Edison, asks that the customer consult an electrician prior to asking for an EV rate, as they have three options in that regard. Good luck.
    2 people like this.
  8. bisco
    52,820
    wow, that's a great electrician! around here, they would want $150 just to come out and look.
  9. bisco
    52,820
    does the quick charge reduce the life of the batteries at all?
  10. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    The only note in the Owner's Manual about prolonging battery life in relation to charging was to allow the batteries to cool before charging.
    Charging at 240V doesn't sound like it will stress the battery that much. If a full charge gives you 11 miles of range, then doing a full charge in 1.5 hours should be about as stressful as driving 11mi/1.5hrs = 7.3 mph.
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Level 3 charging is more of a concern. From what I've read, even with level 3, using it often can reduce capacity by 1% a year so in 10 years if the pack degrades normally leaving 80% from when new you'd be down to 70%. That's only from one article though, I'm sure Leaf owners on here are WAY more versed in this type of charging than I.
  12. LenP
    LenP Member
    257
    69
    Morris County, NJ
    If you have a 110-volt circuit that has other accessories on it, like a light or two you can use it for the PIP.You only need 12 amps to charge the PIP. Your breakers will be 15 or 20 amps on your 110-volt circuits leaving more then enough capacity.
    You can also charge late at night when these same circuits aren’t in use. The slower you charge the traction battery the less heating or degradation is done over the long term. The Prius Plug In has a much smaller 4.4 KW. battery so it takes only 3 hours to charge. Charging at 220 volts is fine too, but it will generate more heat as the charge goes into the battery faster.
  13. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Back when I was really looking at the vehicle.. I put the call in to a local electrician.. he said he would have no problem coming to the house to check on my capacity to use a charger.. and that the most it would cost would be around 1K for a dedicated 220 v charger if I decided to go that route..
  14. HillCountryEVer
    HillCountryEVer New Member
    75
    Kerrville, Texas
    All, please direct me if my question is covered in a different posting. Do PiP owners who use 110/120V service to charge their PiP also use a surge protector between the plug and the PiP charging cable? Has anyone noticed any documentation from Toyota recommending one way or the other?
    Thanks a bunch in advance -
  15. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    DO NOT PLUG INTO A SURGE PROTECTOR OR EXTENSION CORD.
    PLUG directly into the wall.
    I have been advised this by a few folks.
  16. HillCountryEVer
    75
    Kerrville, Texas
    Sounds good, thanks Dianne...
  17. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I use 120 right now but will be upgrading to 240 in a few weeks. I do not use a surge protector. I do use an extension cord (heavy gauge forget the thickness but was recommended by my electrician).
    The 120 plug outside is grounded, on it's own circuit and has a GFCI. My electrician will be upgrading it to a 240 and I'm sending my evse to evse upgrades to convert it to 120/240 interchangeable. This is a cheaper option for the 240 capability.
    HillCountryEVer likes this.
  18. bisco
    52,820
    just make sure you're plugging into a dedicated gfci circuit.
  19. chesleyn
    596
    158
    Los Angeles
    Yes, my outside plug is a dedicated GFCI with it's own circuit running to the new panel in back. My electrician just redid the panel and ran new circuits through the house about a year ago. I'm in an old midcentury with old wiring. It was time for an upgrade.
  20. Sandy951
    Sandy951 New Member
    Baltimore
    I bought a 2012 Prius plug-in yesterday and was hoping I could just install a 240 volt outlet in my garage similar to the one that powers electric dryers or water heaters. Does anyone know if this is possible? I don't want to spend $1000 just for charger, seems like overkill. Thank you.
