Can I charge with a solar array?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Joe Solar, Nov 26, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    PG&E charges me a $13 to $15 fee every month to be connected to the grid. I pay this whether or not I have produced a surplus of electricity. So I know I'm gonna have to pay them at least $160 to $180 over the course of the year, plus any consumption charges. Hopefully my production credits will outweigh my consumption charges so that I'm only paying the minimum meter charges, but I won't know that until next July.
  2. devprius
    devprius /dev/geek
    979
    291
    Build your own EVSE if you can. You like to tinker. This a project right up your alley.
    The cost for me to have an EVSE put in was $500 for the EVSE, and about $2000 in permits, fees, and the electricians time & materials. However, a bunch of that $2000 also covered the installation of a new ceiling fan, fixing a ceiling fan, a new kitchen light, grounding some plugs in the house, and installing a dedicated garage-door opener circuit in the garage for two openers. I figure the EVSE-only portion of that was about $800.
  3. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If I get a quote like that, LADWP may well pay for the whole thing.
  4. devprius
    devprius /dev/geek
    979
    291
    I didn't have a separate meter put in. Just the EVSE.
  5. Joe Solar
    Joe Solar New Member
    Sweet, Vern. My hill seems like the most logical place. My wife doesn't want to see them, and I can't place them directly on the ground, so I thought about making 2 foot tall PVC feet for them in concrete foundations so they would be slightly off the ground while being less visible while still having easy access. With all that soldering and welding equipment, did you make your own panels?
  6. DLee
    DLee Junior Member
    81
  7. mrbigh
    3,686
    699
    Long Island, NY
    [quote="DLee, post: 1691293, member: 94622"Do you say this because only AC is specified? Or, do you have charger schematics or have tried and failed to charge with DC?[/quote]
    That's right, the PiP electrical recharge is specified to AC electrical power.
    DC recharging can't be safely fallow with out bypassing many protection circuits and all of them regarding the LiPO battery assembly.
    But you can be the first to try, and NOT recommended, and taking the risk of the magical smoke fallowed by few explosions and rendering your NEW vehicle out of warranty......:censored:
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I am not too sure about this. The first thing the charge controller will do, is boost and rectify the AC to form high voltage DC. Then it will buck that down to charge the battery as CC/CV. If you feed in a DC value similar to the RMS value of the AC line, it should work fine. This is how many SMPS (Switched Mode Power Supply) devices work. Almost anything plugged into a wall today that is not a motor/compressor can be run off of equivalent higher voltage DC, because one of the first things it does is make it into high voltage DC. The only time this would not be true on a SMPS is if the bean counters decided to shave money by making the rectifier diodes too small to carry the constant load assuming only 2 of the 4 full bridge diodes would be on at any time, at a 50% duty cycle. That way if there was a 10A load, they spec to 6A because it is a 5A load on each pair, 10A at 50%. By running DC, you are running continuous through the 2 diodes, which could heat up. But I would be more than surprised if anything other than cheap junk pulled this trick.
    Joe Solar likes this.
  9. mrbigh
    3,686
    699
    Long Island, NY
    I hope that your technical explanation will NOT being fallow rendering catastrophic out of warranty examples.
  10. DLee
    DLee Junior Member
    81
    The input power may connect directly to the rectifier. The resulting DC voltage is pulsating DC that may be filtered to a steady DC, or it may directly drive the switcher. The switcher may not be very voltage sensitive. It may operate over a broad DC voltage range. A 4:1 ratio achievable
    The charger limits the load, thus the current through the regulator so that may not be an issue.
    And MRBigh is right, this should not be tried unless you know and understand the circuitry inside the charger, and you are willing to suffer if the experiment damages the car.
    Can anyone get a schematic?
  11. Vern2
    Vern2 Junior Member
    50
    Arizona
    2014 Chevy Volt
    Joe Solar,
    I did not build my panels. I bought panels with a 20 year warrantee, Sun Power. There is no other install company that will compare to there install or products, period. $5,000 to install, that includes everything, turn key. I just enjoy the free electricity. This is the complete install with video's. New Page 1. Sun Valley solar Solar Panels Installers Arizona| Solar Panels AZ Took care of everything, except building the 30' x 30' Ramada. I found an out of work young carpenter, single dad. Got some Mex-Workers to dig holes for pillions, they had a great day, ice water, good food and money.
    Vern
  12. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Solar panels are CHEAP. I don't think I could buy the raw materials for what I can buy entire panels for. Currently, I can buy a complete system for less than $4.70 per peak watt, which in my circumstances is the price point at which it is cheaper to pay to service a loan for solar panels, than it is to pay the electric company. In other words, the 'payback' is one day. See if you can find another cheaper solar company.
  13. Joe Solar
    I have been haggling with suppliers in china for weeks. 6x6 inch 3.7 watt solar cells for 80 cents each x 35% tariff x 72 cells in a 6 foot by 3 foot panel = $78 USD. Aluminum frames with joints and rivets (unassembled) = $12 each. Low iron 1/4 " tempered glass (bulk pricing) = $40 each. Dupont sylgard 184 encapsulant = $40 each. Junction box = $20. Caulk, Bus tabbing and solder = $12 at most. Total costs of supplies for a 266 watt solar panel = $202 USD, or 76 cents per watt. I've seen panels on sale on the net for about $1.30 per watt, so there's something to be said for just buying them, except for the satisfaction of attempting to be self-sufficient and a neat project for my kids. That's why if the POCO would not approve of me making my own, my plan B would be to turn it into a charging station for a prius or volt.
  14. devprius
    devprius /dev/geek
    979
    291
    My suggestion: use commercially available panels. They'll be more reliable, carry a warranty, & cost less. Go for a grid-tied system which eliminates the need for a battery bank & charge controller. If you are so determined to make your own panels as a learning experience for yourself and your kids, find a more suitable project that costs a lot less to do. Like maybe an outdoor landscape lighting system. You can do that a lot more easily with a small battery based setup.
    It makes little financial sense these days to invest in a large-scale off griid system if you have easy access to reliable grid power. If your grid-power is a bit unreliable, it's way more cost effective to invest in a genset with a transfer switch than to invest in a large battery bank. I understand the desire to be more self sufficient and green, but if you have to spend 6 figures to do that, your lifestyle is not well suited to achieve that.
    lensovet likes this.
