Can I fly on an airline with a Toyota Prius HV NiMH battery?
Discussion in 'Gen 2 Prius Main Forum' started by frostyjordan, Mar 24, 2022.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Shipping and transportation regulations are mind numbing.
    #21 TMR-JWAP, Mar 27, 2022
  2. Elektroingenieur
    2,515
    3,282
    Three Touring
    I wouldn’t rely on being able to do it, regardless of what anyone might tell you in advance.
    If the Ni-MH battery modules were being offered as air cargo, rather than as checked or carry-on baggage, IATA’s guidance document (PDF) suggests that they probably wouldn’t be restricted under the IATA Dangerous Goods Regulations, if properly declared. (See also 49 CFR § 172.102(c)(1), special provision 130.)
    That might fly over at the cargo hangar, if you were a known shipper, but in the passenger terminal, it’s the operating airline’s FAA-approved carry-on baggage program that would control. Those requirements are enforced by employees whose training typically emphasizes the need to detect and exclude prohibited items, not how to apply the regulations to make shipments acceptable.
    As @TMR-JWAP kindly mentioned, apart from weight and volume limits, there’s a risk that someone in authority would confuse your Ni-MH modules with lithium batteries, which are tightly restricted. Given the serious hazards of the latter, I’d expect most airlines would support an operations agent or captain who makes a good-faith, on-the-spot (but possibly incorrect) decision to honor the memory of Lampe and Bell and refuse to transport a substantial quantity of batteries, of any type, as baggage rather than properly manifested cargo.
  3. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Why you never see MacGyver at check in anymore. He’s been canceled.
    vvillovv likes this.
  4. Another
    1,819
    517
    Naples, Florida
    Ship them flat rate USPS priority mail and be done with it.
    Simple, cheap and reliable in my experience shipping other things. NiMH cells are not hazardous goods according to USPS and are mailable. Just add sufficient padding to prevent shorting.
    348 Corrosives (Hazard Class 8) | Postal Explorer
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    This has been an interesting and informative discussion. I wonder if @frostyjordan has read any of it. So far, just that first post.
  6. Another
    1,819
    517
    Naples, Florida
    Maybe the TSA is detaining him?
    vvillovv and jerrymildred like this.
  7. jerrymildred
    11,517
    14,147
    Tampa, FL
    I was waiting for a comment like that. Didn't need to wait very long, either. :LOL:
    Another and vvillovv like this.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,555
    761
    Southern California
    Definitely pack to prevent shorting. NiMH batteries do not go up in flames all by themselves like Lithium ion batteries, but short a good conductor across its terminals and that will certainly become hot enough to ignite paper or cardboard. Hmm, I wonder if salt solution soaked paper or cardboard conducts enough to do that? I'm thinking "puppy pees out of its crate onto box of batteries". Not a likely event, but not impossible.
  9. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    He's probably stuck in hospital with a broken back from trying to lug a carry-on with 28 modules in it....
  10. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    I fly a LOT. Weekly for 15 years. It would be risky.
    Policy changes often, TSA has written rules, Airlines have there own. Gate agents are flaky even if you have status.
    I've have flown batteries, electronics, guns, ammo, iMacs. etc. I have had no problems on most, $800 in damage that Wasn't covered on others.
    It is a solid MAYBE. Something that has personal value like these batteries are worse if they don't make it then your clothing. Obviously your trying to repair your car and don't want any further delays. The Risk of not having it make it doesn't outweigh the reward of having it actually work and make it. I would do UPS Ground in a well padded and protected cardboard boxes. Divide them into 4 boxes of equal weight and size. It might cost more but I'm a buy once cry once kinda guy.
