Can I get a Solar Panel Kit & A Plug in to co-exsist with my HSD?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bigmahma, Aug 31, 2007.
  1. bigmahma
    bigmahma New Member
    226
    My Car will be like... a mess.. good god..
  2. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    <div class='quotetop'>QUOTE(bigmahma @ Aug 31 2007, 05:43 AM) [snapback]504785[/snapback]</div>
    Short answer: NO
    Long answer: sort of. You can't easily charge the 'traction' or 'HV' battery with an exterior charger. I.E. the PV would invert their 24 or 48V output to 201.6V and know the SOC of the battery... Not going to happen very cheaply or easily. Next to that, you'd need about 1 square meter per kW of space to capture enough energy to make it truly worthwhile. You can add smaller PV arrays to the 12v system with ease but the amount of captured energy isn't likely to amount to much.
    If you really want to use PV, get a pure electric car... then you could use the PV panels mounted on your homes roof to charge your car. Like Darelldd (http://www.evnut.com/)
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Short answer, yes...it's already been done:
    Long answer (question), how much money do you have?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Better answer: It's not worth doing, except as a stunt or technology exercise. You are better off using a PV array on your house at home.
    Tom
  5. oly_57mpg
    360
    <div class='quotetop'>QUOTE(qbee42 @ Aug 31 2007, 03:45 PM) [snapback]505098[/snapback]</div>
    Ding ding ding ding.... We have a winner Bob.... Exactly!
