Can I just drive in ECO Mode??
Discussion in 'Gen 3 Prius Fuel Economy' started by Susabelle14, Mar 14, 2012.
  1. Susabelle14
    Susabelle14 New Member
    Southeast Wisconsin
    I seem to be getting better gas mileage (54 vs 50 mpg) just staying in ECO Mode all of the time.
    Can I do that, or is it bad for the car? My daily drive is a mix of city driving around 30-40 MPH and highway 60 mph.
  2. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    The ECO Mode changes the mapping of the gas pedal. So, you should get better gas mileage. It won't hurt your car. When I get my new Plug-In in a couple weeks, I will drive it 1,000 miles home with the car in ECO Mode.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ECO will also tone-down your heating and air conditioning by lowering your fan speed, etc. If you are comfortable in ECO, stay there. I am and I do.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Absolutely! You can drive in ECO mode 24/7/365 is you so wish.
    ECO mode also regulates A/C use so remember that in the summer if you are feeling like the car isn't cooling enough.
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Yes you can do it. No it is not bad for the car. Congrats on your great mileage!
  6. ProfPlum
    ProfPlum Junior Member
    28
    Nevada
    I
    I drive mine in ECO mode all the time and have for two years now.
    One of the posters correctly mentions that it adjusts how the "gas" pedal affects the engine. But you can accelerate as hard in ECO as in PWR - you just have to push harder on the gas pedal.
  7. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Always run in ECO mode here.
  8. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    ECO mode until we hit the hill than we put it into Power mode.
  9. Socal Pete
    Socal Pete Junior Member
    69
    SoCal
    ECO mode only when I'm on the freeway.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    You do realize that your Prius has the same amount of power in ECO as in Power mode? Switching to Power mode will not climb hills any faster.
    Tom
  11. fjpod
    fjpod Member
    419
    72
    New York
    Eco mode all the time. When I want extra power, I press a little harder on the gas.
  12. El Dobro
    El Dobro A Member
    7,102
    3,282
    I've been keeping mine in ECO, too.
  13. Tideland Prius
    16,670
    Keep it in whatever mode you want! This is why Toyota gave us the option. It's to help make the Prius appealing to a wider range of drivers - those that want a more responsive gas pedal may choose PWR mode and those that need some coaching or just want to be able to fine tune their throttle feathering can use ECO.
  14. sooperedd
    sooperedd Junior Member
    48
    Colorado
    Isn't a Gen III always in ECO mode unless I hit the PWR or EV buttons? What is Normal Mode?
    Just got my 2011 3 weeks and I am still learning as this is my first Hybrid.
  15. Tideland Prius
    16,670
    When neither the ECO MODE or PWR MODE lights on the dashboard is lit up. (So if you're in ECO mode, press the ECO MODE button and the light on the dash should go off. Now you're in normal or default mode)
  16. movingforward
    movingforward Member
    169
    The Great White North
    So if when I'm in normal mode (ie did not select the other drive modes: EV, ECO, PWR) and I stay within the range with the ECO logo light up all the time...does that mean I am really driving in ECO mode but with out the help from the ECU?
  17. qbee42
    18,058
    3,081
    Northern Michigan
    It means you are in Normal mode. All three modes are basically the same, with the exception of pedal mapping. Eco mode makes the gas pedal feel sluggish; Power mode makes it feel responsive. Normal is in between. All three modes have the same power and acceleration.
    Eco mode also dials down the air conditioner and encourages the engine to shut down when not needed, helping to get that last bit of mileage from the tank.
    Tom
  18. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Yes and no. The ECO light you see is basically a graph on what your throttle meter looks like at that particular position regardless of whether you are in ECO, PWR,EV or normal driving mode. When the ECO light turns on within the ECO range, you are consuming less gas reagardless of the mode you selected. As the bar go past the ECO range going into the power range, the ECO light turns off and you in the PWR range where you are now applying more pressure to the gas pedal resulting to more use of gas and considered to be "non-ecomonical". Just think about the higher the speed, the higher the gas consumption is. That is what the ECO light is for. The modes only changes the throttle response. In ECO mode, you press hard on the gas pedal but the car moves forward slowly compared to normal or PWR mode. If you switch to power mode, the response of the car is abrupt as you press down hard on the gas pedal from 0 - 45 mph.
  19. prj
    prj Member
    OH
    I like ECO mode on the highway. A fairly large press of the accelerator only increases the power a small amount, so it's easy to control. It's a lot easier to stay in the glide mode on a slight downhill with Eco.
    But I don't like the slow initial response when driving in stop-and-go city traffic, so I use Normal there. I'll only use Power mode if I need to handle merging in faster heavy traffic, like an on-ramp, or merging lanes on a busy street.
    It's interesting to switch modes while driving at a steady speed with the HSI display showing. After a second or two, the power level on the graph smoothly increases or decreases to match the new mode. (Or I can take my foot off the accelerator briefly to switch modes instantly.)
    Another forum user linked to this graph. Note that all modes end up in the same place when the pedal is floored, so they all produce the same max power.
  20. movingforward
    169
    Just tried driving exclusively in ECO Mode and can't differentiate it from Normal Mode other than the fact that I can modulate my foots in the first half of the throttle bar more easily. In Normal Mode it kicks me out of the first half of the bar faster and it's harder to stay within that range.
