Can I put another set of wheels/tires from another Prius Touring on my car?
Discussion in 'Gen 2 Prius Main Forum' started by andrewsilver, Dec 20, 2009.
  1. andrewsilver
    andrewsilver Enthusiast
    33
    Frisco, TX
    Quick question: Can I take a set of tires and wheels off of another 2007 Prius Touring and install them on my 2007 Prius Touring - or will it affect the Tire Pressure Monitoring system?
    Since the other wheels/tires have a different TPS code, can I just reset the TPS button on my car and it should work - or do I have to bring the car to Toyota and pay them to register the new tires/wheels?
    Thanks in advance.
  2. Patrick Wong
    18,200
    6,493
    You will need to have the new codes registered on the TPMS ECU which requires a dealer visit. If you don't know the codes, the tires will have to be unmounted so that the codes marked on the sensors can be recorded.
  3. andrewsilver
    33
    Frisco, TX
    Thanks Patrick. I was afraid of that.
    Does Toyota typically charge for registering the new codes?
    Are the codes stored anywhere else - like in the owner's manual or on the original bill of sale for the vehicle?
    Are the codes different on each wheel, or can I just unmount one wheel to get the code?
    Thanks!
  4. Patrick Wong
    18,200
    6,493
    I would expect the dealer to impose a labor charge. The code is unique on each wheel's sensor. I'm not aware of an owner document listing the codes.
