Can I remove my passenger seat and drive without issue?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by eatdrumss, Apr 3, 2022.
Tags:
  1. eatdrumss
    eatdrumss Junior Member
    57
    cleveland
    Is it okay to remove the passenger seat without causing any issues or dash lights....
  2. audiodave
    audiodave Active Member
    800
    272
    US
    Should be fine, especially if not powering up the car.
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    You can remove it but the SRS Airbag and the occupany sensor will throw errors and probably give you a dash light.
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Do you want to permantely leave it out, or just for cleaning?
    I'm not sure on the Prius, but it would be best to disconnect the 12V battery.
    Then you won't get the SRS light, that can be a pain to reset.
  5. ChapmanF
    19,054
    Also, if you remove the passenger seat and then reinstall it, the occupant classification system may need to be recalibrated. There is a procedure in the repair manual, to be used with a certain set of known weights to position on the seat, if I remember right (but maybe I'm not remembering Gen 2...).
  6. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  7. Daigi_
    Daigi_ Active Member
    198
    430
    Hacienda Heights
    You can remove the seat, but will need to install a resistor to act as a bypass. I swapped out my driver seat for a Recaro seat. The new seat doesn't use any of the factory sensors. Iirc, it's a 2 ohm resistor.
