Can I replace 1st generation battery cells with 2nd generation battery cells?
Discussion in 'Generation 1 Prius Discussion' started by Oregon Mom, Nov 18, 2019.
  1. ChapmanF
    19,020
    It would be even more precise to say module 37. :)
    Cell 37 would be, I think, be found at one end of module 7.
  2. MArcin91t
    MArcin91t New Member
    22
    Poland, Poznań
    2000 Prius
    I
    Yep, it was module number 37, Cell number 219
  3. Prius23years
    Prius23years Junior Member
    Derby England
    2021 Prius PHV
    Business Ed. Plus
    Just to comment that the Gen 1 NHW11 has 19 "blocks" meaning 38 modules, not the 14 blocks and 28 modules which you mention which applies to the Gen 2 Prius.
  4. ChapmanF
    19,020
    Thank you for correcting that. I had both gen 1 and gen 2 in mind because the thread mentioned both, but it's in the gen 1 forum, so I should've used the gen 1 numbers.
    Prius23years likes this.
  5. Prius23years
    Derby England
    2021 Prius PHV
    Business Ed. Plus
    Congratulations on your temporary HV battery repair! I can see why you wisely placed the longer replacement Gen 2/3 module at the end as that minimised the deformation of the bus bar. If you have any more original modules fail then you may be interested to know that I have kept several of the Gen 1 modules from my brother's repaired Prius, including 4 replacement modules bought from ebay that were manufactured in December 2010 which as I said in my post I think must be from a later Toyota manufactured factory replacement spare HV battery and appear to be in very good condition. I keep them regularly charged, I last charged the 4 2010 modules several weeks ago and they are all reading 7.78V at the moment. So if you should ever need some Gen 1 module replacements let me know.
    MArcin91t likes this.
  6. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    I got one for you, no nursing required. Only 88k. Rare Ice blue. I'm the second owner.
  7. Iris_TheRainbow
    Iris_TheRainbow New Member
    22
    Illinois
    2003 Prius
    Wasn't the ice color available for the whole run of the car? looking at when what colors were available I'd expect golden, Blue Moon and black to be rare. Aqua ice was available the whole time.
  8. ronlewis
    1,059
    205
    texas
    2001 Prius
    I didn't look up the colors and used the wrong name. The ones that are rare are the Blue Moon and Black. Aqua and metallic silver were the most popular; I've had at least 5 of each of those colors. Several whites and several greens. The dark blue wasn't as popular. Hard for me to tell the difference in the two silvers and the different whites.
    Also, I just go by the colors cited by the auctions and they don't distinguish between the silvers and whites. I just rarely see black ones at the auctions and not many Blue Moons.
  9. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    Search term "2002 Prius paint codes" brought up this link: Toyota Prius Exterior Paint Colors Paint Codes & Color Charts . It shows six colors offered in 2001-2002 (see chart). Black and golden pearl were added in 2003, and blue moon pearl was dropped. And that's it. I don't think I've ever seen black or golden pearl. Clearly the decision-makers at Toyota were thinking "cool" colors, for the most part.
    #29 Trombone, Apr 29, 2026
    ronlewis likes this.
  10. ronlewis
    1,059
    205
    texas
    2001 Prius
    Yeah, I saw that. I used to have one of the gold ones. It said bronze on the title but gold on the auction description. I've seen <10 black ones over many years watching the two biggest public auctions all the time. At one time, I had all the '02 colors in cars with <100k miles, except a black one. Never found one and then sold off some of the set.
  11. Trombone
    389
    130
    2002 Prius
    Well, according to the chart, there was no black until 2003. Maybe you just saw a really dirty '02! (Oh, you said you never saw one. My mistake!)
  12. MArcin91t
    22
    Poland, Poznań
    2000 Prius
    I
    Have I just made a makeshift job of something again? Maybe.:D If it lasts a year, I'll be happy. Next year I'll try to do it properly.
  13. Hayslayer
    Hayslayer Active Member
    534
    325
    Now all you have to do is jerry rig the busbar harness to get the bus bar to fit where the 2 different sized modules meet. or make two custom busbars with a couple 90 degree bends in them so the ends sit flush on the module terminals. Odds ar those modules are going to be incredibly out of balance. Most Gen 1 modules are in piss poor condition.
  14. MArcin91t
    22
    Poland, Poznań
    2000 Prius
    I
    I thoroughly checked all the modules. It's not that bad, they should be sufficient for a while. Currently, the worst module is 3800mAh. Previously, five were below 3000mAh, and three others had quite high internal resistance. If you look at module 38, you'll notice that it had already been replaced with a newer type, and I managed to do it without modifying the bus bar. It adjusted itself.
  15. Hayslayer
    534
    325
    It adjusted itself.
    Yes, because if you torque it hard enough, even those little copper bars will bend and deform and terminals will flex and bend......until you snap off a terminal. Just be careful. I hope it works out for you!!
  16. MArcin91t
    22
    Poland, Poznań
    2000 Prius
    I
    I actually took a risk and screwed it on roughly without paying attention to the terminal. It worked without a problem.
    Other Side
    Generally, consider these combinations of mine as an experiment to see if it can be done. I'm keeping in mind that these are old modules that won't last long, and I'll have to look into them again. I like to experiment and have several cars, so if something breaks, I simply switch to another car. If someone treats the NHW11 as their main and only car, I don't recommend this solution, unless their budget doesn't allow for replacing all the modules.
  17. MArcin91t
    22
    Poland, Poznań
    2000 Prius
    I
    I solved the issue of incompatible temperature sensor mountings in this way.
