Can I replace combination meter in Prius 2005 from salvage yard Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Greenhybrid, Jan 26, 2020.
  1. Greenhybrid
    Greenhybrid Junior Member
    IN
    2003 Prius
    Hi Folks,
    Combination meter in my Prius 2005 is not working. I did try to DIY by replacing the capacitor with 220uF, 16V capacitor. It worked for 15min. and then stopped working. Seems it got short as there was plastic burning smell coming out. Can I replace it with other combination meter from salvage yard? Or how can I get the original combination meter repaired as it seems that it got short? Please suggest. Thanks in advance for your help.
    52,875
    'texashybridbatteries'
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    yep... What @bisco said...
  4. strawbrad
    953
    1,007
    Yes,
    Any 2004 or 2005 Prius combination meter will work. The millage will read whatever the junkyard car had.
    Texas Hybrid batteries can set the millage to match your car.
  5. bisco
    52,875
    and the bad capacitor has already been replaced
  6. strawbrad
    953
    1,007
    The OP ruined his combo meter by replacing the capacitor. It's not an easy bit of soldering.
  7. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    OP - It definitely sounds like something went wrong when you tried to fix the old meter. We can fix a lot of repair attempts but once they short out and burn up the board is probably trash.
    Luckily we have a surplus of those 04-05 meters so I’m not worried about getting a usable core back. If you want to order a new meter it will already be upgraded with new caps and programmed to match your mileage. It would cost you $150. Free shipping and lifetime warranty.
    PM me if you have any questions.
    Matt
    TX Hybrid
    M in KC, Raytheeagle and strawbrad like this.
  8. Greenhybrid
    IN
    2003 Prius
    Thanks folks. I did replace combination meter from salvage car, however, nothing lights up on dash board. Even the blinking red light (which has car shape with key image inside) is gone. Any guesstimate what might have gone wrong? Either the salvage combination meter was bad, however, even with my previous original combination meter, that red blinking light (car shaped with key image inside) was working. Do combination meter have different circuits where even if it is bad, the circuit involving red blinking light with car and key image inside can still remain active?
  9. J Leonard
    J Leonard Junior Member
    Central Florida
    Because of the security involved, with respect to the key etc. I would think you will have to use Techstream or something similiar to install and register the combo meter. The salvage meter could be perfectly fine just not registered to your cars other ECUs. This is my 1st day here but it is a similiar thing to other cars. I don't know the process but imagine it is documented here somewhere. Good luck.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Going on 2 years with my Texas Hybrid rebuilt meter works great thanks Matt.
    M in KC and Raytheeagle like this.
  11. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Did you use a CM from another 2004 or 2005?
    The 2006-2009 CM does not just plug and play with a 2005 Prius. You need to also replace the light cluster from your 2005 with a light cluster from a 2006-2009 in order to use the 2006-2009 CM. In addition, you will also need to remove the TPMS LED from the newer model light cluster before fitting it into your 2005.
    valde3 likes this.
