Can I transplant smart key system into dumb key prius ?
Discussion in 'Gen 2 Prius Main Forum' started by corey, Apr 13, 2019.
  1. corey
    corey Junior Member
    Omaha, Nebraska
    Hi guys, i just got a 2006 Prius with a dumb key. I have 2 parts prius with smart key systems. I am swapping the interior from the 05. What do i need to swap into the new prius so it has the smart key system ?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    A lot including the MFD. but I don’t think you can swap that with a 2005. I would let it go.
    52,878
    i think you have to add antenae, there's a thread here somewhere.
  4. corey
    corey Junior Member
    Omaha, Nebraska
    I have tried searching, but cannot find anything ..
  5. corey
    corey Junior Member
    Omaha, Nebraska
    I have an 05 and an 07 I can use as donors ... I don't mind if it is a lot of work ... Just need a good list of what I need to pull to make the swap.
  6. bisco
    52,878
    'How to add SKS to the hatch and passenger door on a 1 door SKS Gen III Prius' by @BrettS
    sorry, it is gen 3, but maybe you can garner some knowledge
  7. Skibob
    2,912
    1,505
    Northern California
    And neither one has a 2006 main computer. How is the car going to work/pass emissions with the wrong year computers?
  8. Skibob
    2,912
    1,505
    Northern California
    There are 5. Check your owners manual.
  9. bisco
    52,878
    that's why i pluralized it
  10. Skibob
    2,912
    1,505
    Northern California
    No you pluralized it because you had no idea.
  11. bisco
    52,878
    thanks for the correction
  12. corey
    corey Junior Member
    Omaha, Nebraska
    This seems to be adding to an already existing smart system ..
  13. corey
    corey Junior Member
    Omaha, Nebraska
    So .... No one knows for sure or has done it ? I was hoping to have a plan as I have to send the donor Priuses to scrap here soon ...
  14. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    I'm in the same situation. I'm driving an '05 with the dumb key system while there's an' 08 with a smart key system sitting in my driveway that won't run because the inverter is bad or so the scan tool says. I would like to have the smart key features in the running '05 too.
  15. bisco
    52,878
    good luck!(y)
  16. Skibob
    2,912
    1,505
    Northern California
    Yep.
  17. Center of Gravity
    Center of Gravity Junior Member
    25
    New Orleans
    It is my understanding from someone year ago when I inquired the same, that you cannot and it's because of the lack of the sensors. I'm not sure who you can talk to other than possibly Auto be Yours, or any Prius based rebuilder who have the expertise and could sell you any parts directly, which would be better than tearing apart a perfectly good car that just needs an inverter. Frankly, just buy a used one of those and drive the other car...
    That's all I got
  18. Center of Gravity
    25
    New Orleans
    But if you find an answer for sure please post here so that I know. I have two Prius and one of them at 300,000 miles could be a candidate for the 250,000 mile vehicle.
  19. bisco
    52,878
    yeah, no one knows for sure, unfortunately
  20. bisco
    52,878
    but one thing is known: if you're smart enough, capable enough and determined enough, anything can be done.
