Can I use 240V 30amp or higher amp cable to charge 2012 Toyota Prius Plug-in instead of 120V 12amp?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Angry bird, Jan 24, 2019.
  1. Angry bird
    Angry bird Junior Member
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    Yes, you are talking about "level two" charging, and the PIP can do that. You will need a level-two charging cable which you can find for as little at $200, and a 220V outlet installed to match the cable.
    jerrymildred and Pluggo like this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You can use Level Two charging, the Prius PHV is still limited to 12 Amps, so it halves the time of 120 volts charging.
    #3 JimboPalmer, Jan 24, 2019
    51,961
  5. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    At home I have a 40 Amp/240 volt setup. It has its own line back to the breaker box. However the first gen will only pull 13 Amps while its charging, that doesn't change. I deliberately had the system oversized in preparation for whatever comes next. It is trivially easy to have the electrician add a 120 V outlet while he is installing your charger. Quite handy for various car related purposes, totally beats running an extension cord through the door.
    john1701a likes this.
