Can I use a 2010 fob in a 2005 vehicle?
Discussion in 'Gen 2 Prius Main Forum' started by acz, May 4, 2019.
Tags:
  1. acz
    acz Grandpa
    16
    Houston, Texas
    2003 Prius
    Last year a friend totalled her 2010 (I think) Prius. She salvaged the two key fobs and gave them to me in case they might be usable in some way, some day.
    Well, it seems that now we are down to one fob on our 2005 Prius.
    Is it possible to program the later model fob to work on the 2005? I read a long time ago that there is some procedure for programming which can be done by the owner without paying $200+ to a dealer.
    So, I would appreciate any advice from the wise people here on the forum.
    Thank you.
  2. acz
    acz Grandpa
    16
    Houston, Texas
    2003 Prius
    Aha, I found the writeup of "the chicken dance" for fob programming, thanks to usnavystgc!
    The remaining question is will the 2010 fob work?
  3. JC91006
    16,673
    8,518
    No on the 2010. You need a new 2nd gen fob
  4. lexidium
    lexidium Active Member
    284
    133
    manchester
    But you should get a reasonable price on Ebay for it and then buy a 2nd gen with it.
  5. oldtechaa
    oldtechaa Active Member
    336
    223
    NZ
    2013 Prius Alpha
    Did anyone ever find a way to reset used fobs? Does that require Techstream? Otherwise, those fobs would be useless.
