Can I use CTEK 4.3 Fully Automatic Charger to charge 12 V 5Ah battery?
Discussion in 'Newbie Forum' started by Sanjay Goel, Nov 9, 2018.
  1. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Usually that’s how websites arrange things.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    I think you should check the voltage at the battery BEFORE you disconnect it.
    And then again after you disconnect.
    IF.....the battery voltage drops a lot when it is disconnected from the charging source......then it almost certainly is bad.
  3. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Thank you Sam sir!
