Can leaving the door open run down the battery and am I going to recover from 5.5v
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 16, 2019.
  1. ChapmanF
    18,213
    A 12 volt battery in back that is down to 5.5 volts, though, will drink up considerable current from your jump source, until it is up to a more reasonable voltage.
    Johnny Cakes likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    That might be true in most cases but not all.
    If/when the onboard battery is REALLY low, it can drag down the jump source voltage too, resulting in a "system" voltage that still is low.
    That likely IS the case when the battery initially reads 5.5 volts.
  3. tonynap
    tonynap Member
    43
    38
    NY
    I'd pull it and parallel charge it.
  4. Mendel Leisk
    41,463
    In the 3rd gen Owner's Manual the recommend to delay start up for 5 minutes after connection to the assisting vehicle, and to have it running at elevated rpm for that time:
    That said, I think it doesn't matter that much.
    Haven't done that in the past, but sounds like a good idea: gives the dead battery more of a chance. I'm going to start doing that.
    #24 Mendel Leisk, Dec 18, 2019
    Grit and Johnny Cakes like this.
  5. sam spade 2
    7,035
    2,803
    2017 Prius c
    What exactly doesn't matter that much ?
    Having a jump source of sufficient capacity connected a sufficient amount of time absolutely does matter.
    Fact, not random opinion.
  6. Mendel Leisk
    41,463
    I guess I just threw that in, cus I've never waited 5 minutes, say after connecting my jump pack. But fair enough, likely a good idea: give the knackered battery more of a chance. (y)
  7. sam spade 2
    7,035
    2,803
    2017 Prius c
    Toyota and I both thank you for your concurrence. :)
    (Sorry, couldn't resist.)
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Manual says “increase the speed of the second vehicle” so that means driving down the road side by side with jumper cables on both batteries and have the second car accelerate? I hate to be the lawyer for Toyota on thAt if a road accident like that was the result.
    Johnny Cakes and Mendel Leisk like this.
  9. Mendel Leisk
    41,463
    My screen grab says increase engine speed, c'mon... :rolleyes:
    Grit likes this.
