can not put gas in. Recall item?!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by prius_deep, Apr 2, 2017.
  1. prius_deep
    prius_deep Member
    105
    38
    road
    I have read here where other people have had this same issue, you go to fill up and the 2016 prius will not let you fill it.
    It happen to me for the first time today, tried to put in gas, but the car kept acting like it was full - 4 to 5 time.
    Read the message inside the gas door, '~ 30 minute window, or push the button again~'.
    Pushed the gas door release again and I was able to fill it up the total of 7.682 gals.
    Might be a software problem - 30 minute timer - or a mechanical problem or both, but a problem will only get worse not better over time.
    how many more of you have had this issue? and it's a safely issue, your trying to pump a flammable liquid and it keeping trying to come out.
    this might be a Recall thing what do think?
  2. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Was this your first fill? I seem to remember someone else had the same problem on PriusChat, but after the first fill I "think" it corrected itself. It could also have been a fault with the fuel pump.
    To be honest, I didn't take a lot of notice, as our fill system is different here. Even so, my first fill I had to do very slowly, I've used the same pump since and it has filled at full speed every time since.
    52,807
    welcome to priuschat!(y)
  5. alanclarkeau
    7,045
    7,593
    Another question - I assume you've checked with your TOYOTA dealer.
    That's always the best place to start - trying to escalate to a RECALL would be unlikely to get anywhere if you haven't had it checked by service technicians.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I remember the problem mentioned on here back along. I don't think it's a generic problem as long as you don't dawdle after opening the filler flap. Like you say, after 30 seconds the release button has to be pressed again because the time lock has kicked in. It's just one of those little Prius quirks you get used to after a while and it never happens again.
  7. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
  8. prius_deep
    prius_deep Member
    105
    38
    road
    no, from inside the gas door and 2016 owner's manual (USA) page 264 'finish refueling within 30 minutes. if more than 30 minutes passes, the internal valve closes. in this condition, fuel may overflow during the refueling process.'
    minutes not seconds.
    RCO likes this.
  9. prius_deep
    prius_deep Member
    105
    38
    road
    maybe some hoses are naked, some have a ~bonnet~ etc, to keep vapors from escaping. If the prius was design in japan who knows what hose(s) designs are used there. Like I said here in the US there many designs, which may or may not hit a latch.
  10. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have also periodically had this problem. Two days ago it happenned again and pressing the fuel button under the dash again fixed it for this fill up.
    JeffD
    eric1234 and RCO like this.
  11. Prodigyplace
    12,711
    11,848
    Central Virginia
    We do not have the quick fill pumps you have. Toyota USA gives us 30 minutes to fill up not 30 seconds. :LOL: :D
    RCO likes this.
  12. eric1234
    392
    201
    Hamden, CT
    Sounds like my observation may be correct. I've been careful to ensure that the large rubber "shroud" on the pump avoids the latch, and have not had the problem reoccur. I've also noticed that the large rubber "shroud" is located almost perfectly to contact the latch.
    I'd love to conduct an experiment to trigger the latch while filling to confirm my observation, but am not keen on the mess (and/or possible damage to the evap system) that would result from such an experiment... ;-)
