Can OEM leather heated seats be swapped from a 2010 V to a 2010 III?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Steve Bachman, Jul 28, 2016.
  1. Steve Bachman
    Steve Bachman Junior Member
    Ann Arbor, MI
    2002 Prius
    I
    My wife's beloved 2010 trim level V (five) Prius was rear-ended and likely totaled. We are waiting for Allstate to inspect it. Meanwhile, we found a nearly identical 2010 III for sale, but she loves her heated leather seats. If they total it, I'm considering asking Allstate to sell us the wreck, so I can swap the seats and the larger-rim wheels from the V to the III. Does anyone know whether this can be done, or are there issues with the III wiring harness, air-bag system or the computer not "recognizing" the seats from the V?
    Also, I'm considering having a mechanic pull the high voltage battery from the V, since it only has 110K miles and the III has 250K. I'd probably just store the one from the V until needed. Any issues with putting a battery from a V into a III? Any storage issues, like temperature or needing to maintain a charged condition?
    Thanks for any thoughts!
    Steve in Michigan
    Dylan Doxey likes this.
  2. qdllc
    qdllc Senior Member
    1,377
    400
    I would PRESUME the answer is yes. Overall, parts are made identical to save money. The better seat should have the same mounting holes and bolts as the one being replaced. The issue is if the wire harness connections are present to power all of the features.
    Let us know how it works out. I've been tempted to "upgrade" my 2013 Prius Two seat with one from a Prius Four.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    My friend @sfv41901 installed upgraded (softex + power) seats in my Prius. My original wiring harness needed to be supplemented to supply power. Also, in this particular case, there was an issue with the female seatbelt buckle being incompatible with the seatbelt in the car. We had to swap out some seatbelt hardware to resolve that.
    In short: Yes it can be done.
    Caveat: It is not completely plug-n-play.
    Robert Holt, sfv41901 and Burna J like this.
  4. andino
    andino Senior Member
    746
    551
    San Jose, CA
    You should also swap out the leather steering wheel on the V for the plastic one in the III
    sfv41901 and Dylan Doxey like this.
  5. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Take the foglights and turn signal stalk too.
    sfv41901 likes this.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    In short, yes it can be done.
    I've swapped out cloth seats to Softtex seats for both @Dylan Doxey & @Burna J
    I've also swapped the CT200h seats into my Prii.
    If u are going to be buying the wrecked Prii back, u can harvest a lot of what's needed.
    Seats will almost be PNP. SRS will plug in. U will need to harvest both positive & ground wires to get the seats to move. I'm pretty sure u won't have the seat belt latch issue I had with Dylan as both of ur Prii's are 2010.
    iPhone ?
    Robert Holt, Burna J and Dylan Doxey like this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    What u won't be able to get working easily is the heating function. Getting this to work involves tearing the entire dash apart from both Prii's since the wiring won't be in the 2010 III.
    Best bet here would be to install aftermarket heaters
    iPhone ?
  8. huxington
    huxington New Member
    Los Angeles
    Wouldn't it just be easier to do the clazzio skins/heating pad option?
