Can One Run the Prius without the MFD?
Discussion in 'Gen 2 Prius Technical Discussion' started by undertoad, Mar 6, 2021.
  1. undertoad
    undertoad Junior Member
    17
    Seattle
    Will a 2007 Prius run and drive without the MFD connected?
  2. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    Definitely. I ran mine without while I waited for the replacement to come in.
  3. undertoad
    17
    Seattle
    Fantastic. Thank-you.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Cant turn on heat or ac though.
  5. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    You can if you have the steering wheel buttons. You can still change the temperature also.
