Can P0A80 code occur without actual hybrid pack failure?
Discussion in 'Gen 2 Prius Technical Discussion' started by PaperPrius, Feb 7, 2017.
  1. Sure, it should last at least a few months.
    0 vote(s)
    0.0%
  2. Yeah, but I suggest the Prolong Kit.
    0 vote(s)
    0.0%
  3. Nope, time to get a cheap "refurb."
    0 vote(s)
    0.0%
  1. PaperPrius
    PaperPrius New Member
    27
    Longwood, FL
    Sorry in advance, but this is going to be a fairly long post.
    I have a 2007 with just over 145k miles which just gave the RToD. I pulled the codes with an OBDII tool at Advanced, and got a P0A80 and P3015, indicating a malfunction in Block #5. (Please feel free to correct me if I get anything wrong here. I've owned hybrids for almost 12 years, but this is the first time I've delved into an HV battery issue by myself.) Though my searches found that the P0A80 code could have a generic "replace hybrid battery pack" meaning, I've found other sources that say it's deterioration due to overheating. So, this, coupled with the fact that the cooling fan comes on high as soon as the vehicle is turned on lead me to believe that Block 5 possibly has a shorted cell. My girlfriend reported the RToD shortly after going too fast over speed bumps she couldn't see. Is it possible the jolt cracked the separator between the plates causing a short?
    Now, the reason I asked the title question is that I have a 2005 with a guesstimated 360k miles (odo stopped at 299,999) which is only giving the P0A80 and P3190 (poor engine power), with no indication of a bad block. Thinking that the HB code was from overheating, I pulled the fan, and it is caked with dust to the point that it may not be producing any airflow. IMG_20170207_191132570.jpg
    For comparison, here's the fan from the '07, which will be cleaned before reinstallation.
    The vast majority of the mileage was accrued delivering newspapers, which seems to have been good for the battery pack, as I was still getting about 45 mpg with a bad O2 sensor (bank 0, iirc), probably fouled by burning oil, before the tranny broke. The pack still has enough juice to start the gas engine, though the engine shuts down after about 15 sec of putting out noxious fumes, and I get both error codes back after having cleared them.
    Thanks to the excellent tips from users of this board, I plan on replacing the bad module(s) in the '07 pack. (Questions about that will be coming in a different post, when I get ready to do the rebuild.) However, I really need the car back on the road ASAP. So, is it possible the '05 pack is in good enough condition to be transplanted in the '07 as-is? Is there a way to tell without cracking open the case, or performing plug and pray?
    Also, is the Prolong Battery Reconditioning Package a good option for testing modules, and balancing and conditioning a battery rebuild before use? How much would it improve my chances of a successful transplant as I described? How difficult is it to wire in?
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Prolong battery extender and conditioners are good tool for doing any work on hybrid battery
    If you go this route.....once you have your pack it will be easy to inspect and check if there is any cells bad and need replacing....
    And what you do for living I highly suggest. First mentioned tool.....it will definitely give you more life
  3. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    If you seriously intend on working on your Prius, then you need some basic diagnostic equipment one of which is a code reader. You will need an interface cable and a spare working laptop. Get a VxDiag or Mini-VCI interface cable and don't let price be the deciding factor on these two, you truly get what you pay for. Both come with Techstream software. If you succumb to the pull of cheaper price and get the MVCI, make sure you have copy of Win XP or Win 7 (32-bit), otherwise you will have no end of trouble with the install.
    Second, get a digital multimeter (DMM), A unit in the $25-$35 price range from Harbor Freight will suffice.
    Once you have Techstream up and running you can look at a lot of the sensors in the HV battery and will be able to do a rudimentary battery load test that will show you in short order which modules are bad.
    Maybe, but I doubt it.
    Yes, with Techstream, see above, but the HV battery will need to be installed in a car that can at least get to IG-ON, but preferably it needs to be able to be made READY.
    No.
    Yes, but will not be able to do anything for modules that have already failed.
    If you replace "the whole kit and caboodle" including the electronics and wiring at the left side of the battery case, then it should be relatively straight forward. Use your newly acquired DMM to prob any electrical connections for live voltage, so you are aware of where to be careful, and use your newly acquired linesman gloves to be doubly safe when handling the battery with the bus bars still installed.
    Be safe. Hope it goes well for you.
    #3 dolj, Feb 7, 2017
    Brian in Tucson and m.wynn like this.
  4. Samprocat
    491
    297
    Lincoln, NE
    explained ......well....
    dolj likes this.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    It has been previously reported by a batt expert that a dirty fan can on rare occasion result in a P0A80 code.
    I don't think I could find the old post, but I sometimes give the advice to check the fan upon P0A80.
  6. dolj
    dolj Senior Member
    8,630
    4,384
    That is true and the '05's fan is certainly "gunked" up. The '07, not so much.
  7. PaperPrius
    27
    Longwood, FL
    I thought I had read that, too, but I wanted to get verification. Also, with well over 300k miles on the pack, I wanted to see if the experts thought it was possible that the way I used it has effectively been reconditioning it, so that I might get a few thousand more miles out of it. The 07' I bought used with 124k miles, and I could tell by its condition it wasn't used the same way I used the '05.
    And, from what I think I understand, that gunk would almost certainly cause an error, even with a brand new pack. The heat build-up from lack of airflow could inhibit proper operation whether the battery was charging or powering the MG, and even if it was operating fine, I'm pretty sure a sensor would still report the high temp to a control module, causing it to throw a code.
  8. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    With a battery fan that dirty, little to no air is moving across the battery. This will cause the battery to overheat during use, and trigger the P0A80 code. I would clean the battery fan so that it can be cooled properly, perform a couple in car reconditioning cycles with the Prolong Battery Reconditioning Package, then re-test the battery by driving the car. There is a good chance that will be enough to get the car back on the road and extend the battery's life.
    If reconditioning enough is not enough, our load tester is ideal for quickly and easily identifying failed modules. Here's how it works:
    Prolongâ„¢ Battery Module Load Tester – Hybrid Automotive
    Once failed modules are identified, replace them with quality used modules (we can refer you to a trusted supplier). We recommend replacing the first failed module as a block pair, then save the stronger module from the old block to use if/when a second module fails. This will keep the blocks matched as closely as possible within the pack. You will need to cycle the pack one or two more times to equalize the replacement modules with the rest of the battery.
    Walking through the above process will get you a battery that is in equal or better condition than any 'refurb' pack out there - and it half the cost. And you will know the history of the pack, as opposed to the roll of the dice unknown refurb pack.
    Totallylost likes this.
  9. PaperPrius
    27
    Longwood, FL
    That's what I was thinking, since the OBD scanner found no faulty blocks. Not long before the tranny died, I had a scan done that showed no battery codes. I had other issues that were throwing codes (part of why I didn't invest in replacing the tranny), so I missed when exactly the P0A80 code first appeared. I'm hoping that the pack is still relatively (at over 300k miles) healthy. As far as reconditioning goes, I know my limitations and don't trust my attention span to step down the light bulbs. Unfortunately, your new discharger with auto-shutoff probably wouldn't get to me before early April if I pre-order. Do you think balancing alone could improve the health of the pack to get me by until then?
    I was planning on rebuilding the pack from the '07, your products seem to be just the tools I need to do a proper job of it with a minimal investment of time, and I'd rather spend the money on tools than on a refurbed pack. I could build a load tester myself for a little less than what you charge, but that would take time. BTW, you might consider a package that adds the tester cables to your reconditioning package for use with the MM already included. I'm also surprised that there is no discount on your packages over buying the components separately...
    Anyways, I'd appreciate the referral to the module supplier, since you can never be certain of what you'll find on the web. Also, I haven't been able to find high-voltage protective gloves that I think will allow me to handle 8mm nuts. Any suggestions? (And maybe you could add some to your packages in the future.)
  10. jeff652
    607
    624
    Idaho
    We are in track to ship the pre-orders in mid March, but since your battery has coded already reconditioning would be preferred over charging/balancing alone. It really depends on the battery. If it's in better condition charging/balancing alone is probably enough, if it's on the weaker end of the spectrum, reconditioning is the way to go. To ensure the highest chance of success, we recommend performing the full reconditioning treatment.
    All of our products are hand assembled here at our California location by one of our five part time employees. We have direct labor costs, product liability insurance, workers comp insurance, and all kinds of other fun overhead to deal with. In spite of these we try to create as many American jobs as possible. We also try to offer our best pricing on all of our products right up front, which is why the bundles are the same as the sum of each individual product.
    #10 jeff652, Feb 8, 2017
    Raytheeagle likes this.
  11. PaperPrius
    27
    Longwood, FL
    I figured small-scale production costs were keeping you from offering discounts on the packages, especially when you factor in R&D costs for a relatively small number of units sold. I think I'm going to order just the discharge ready package for now, pre-order the new discharger, and hope for the best. Charging/balancing should at least keep the cells from reversing, if they're in danger of doing so, and I'm afraid there's more danger of me ruining modules trying to use the simple discharger. Just to verify: the pre-order discharger does automatically drop the current as needed to safely get to the voltage set for that discharge cycle and shut itself off at the end of the cycle?
    EDIT: One more question: Do I understand correctly that the Prolong charger for the 2010-2015 Prius can be used for 2004-2009 Prii, but not the reverse?
    Also, the module supplier and any suggestions for gloves?
    By the way, thanks to everyone for the help. Being new to delving into the HV battery, I'm trying to gather as much info as possible to make sure I do it right from the start.
    #11 PaperPrius, Feb 8, 2017
  12. jeff652
    607
    624
    Idaho
    You are correct, the new Prolong Battery Discharger will automatically taper the load down to maintain safe levels as the battery dischargers, then turn itself off & audibly beep when done. The Gen2 and Gen3 Prius use the same charger unit. The plug-and-play car harnesses are different, but the charger itself is the same. For modules, send me an email or PM and I will pass you the info. Gloves are not needed unless you prefer to be abundantly cautious. The 2004-2009 Prius plug-and-play car harness installation instructions are located here (so you can get an idea of the process):
    2004 - 2009 Toyota Prius Plug-and-Play Car Harness Installation - Hybrid Automotive
  13. PaperPrius
    27
    Longwood, FL
    I looked at the install before I had even started this thread. Seems pretty simple, but I was concerned about the voltage underneath the white tabs, since I read somewhere it could be 120V even after pulling the safety disconnect, and I will need gloves when I crack the case for the rebuild.
  14. PaperPrius
    27
    Longwood, FL
    So, I ordered the Discharge Ready kit, and hopefully I'll be able to pre-order the new discharger this coming week, if finances permit. I have a few more questions, and then I think I can leave you alone, at least for a while.
    On the battery with the failed block code, is it possible a full reconditioning could bring it back to life, since the code could just be that the performance of one of the modules is way out of sync with the rest of the pack?
    Before load testing modules, is it a good idea to at least balance the pack, if not attempt reconditioning? What are the dangers if a module has gone bad, like from a reversed cell?
    I haven't found any corrosion so far, but if I do while installing the harness, will vinegar effectively stop any I may find?
  15. PaperPrius
    27
    Longwood, FL
    UPDATE: So, I installed the harness and charger early this morning. I left the main power from the pack and the 12v disconnected after the transplant. When I reengaged the pack's service disconnect, the charger dropped to 209v at .349a. As of this writing, almost 1.5 hours later, I'm at 227v with amperage fluctuating between .348 and .349. So far, so good, I think...
  16. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
  17. PaperPrius
    27
    Longwood, FL
    Since you have a Prolong setup in your Highlander, I wonder if you could answer a question for me. (BTW, I also have a 2006 Highlander Hybrid with over 400k miles, only one HV replacement at just over 300k, but a ton of other problems.) Nowhere in the instructions did I find anything that said how you would know when the balancing was done. Will the unit shut itself off?
  18. Samprocat
    491
    297
    Lincoln, NE
    Go to ProLong site....and read all over again......or email to the ProLong Owner....he will tell you from first hand...
    Question....after balancing what was your Hybrid battery voltage
    It will beep and turn it self of
  19. PaperPrius
    27
    Longwood, FL
    OK, so it will turn itself off. Since that's the case, it must still be balancing. It's been reading a steady 240v for several hours now, and .348a with the very occasional dip to .347a. The steady 240v is what concerned me, since that should be max voltage, right? Or is that just the voltage the unit is currently trying to feed into the pack, but it's not quite there yet?
  20. PaperPrius
    27
    Longwood, FL
    And now we're up to 241 volts and steady...
