Can P0A80 code occur without actual hybrid pack failure?
Discussion in 'Gen 2 Prius Technical Discussion' started by PaperPrius, Feb 7, 2017.
  1. Sure, it should last at least a few months.
    0 vote(s)
    0.0%
  2. Yeah, but I suggest the Prolong Kit.
    0 vote(s)
    0.0%
  3. Nope, time to get a cheap "refurb."
    0 vote(s)
    0.0%
  1. genchau
    genchau Junior Member
    Los Angeles, CA USA
    2001 Prius
    You don't need an old laptop to run techstream. I currently have techstream running on a Surface Pro 6 running Windows 10 64-bit. Techstream installation instruction is here: Sorry I can't post links yet, but try searching this: 150824-solution-mini-vci-toyota-tis-techstream-8-x-windows-7-8-64-bit . Another suggestion is to buy Mini VCI v2.0.4. This version will allows for TPMS programming.
    I also want to chime in on "Torque Pro" android app, and using a bluetooth OBD2 adapter. This is actually my prefer way to log data. Here's a list of all the information I logged today to diagnose the DTC, P0A80. All this data was logged at 10Hz.
    [PRIUS]HV Battery Air Intake Temp(°F)
    [PRIUS]HV Battery Block # with Max V(Num)
    [PRIUS]HV Battery Block # with Min V(Num)
    [PRIUS]HV Battery Block Count(Num)
    [PRIUS]HV Battery Block Highest Volt(Volt)
    [PRIUS]HV Battery Block Lowest Volt(Volt)
    [PRIUS]HV Battery Block-01 Voltage(Volt)
    [PRIUS]HV Battery Block-02 Voltage(Volt)
    [PRIUS]HV Battery Block-03 Voltage(Volt)
    [PRIUS]HV Battery Block-04 Voltage(Volt)
    [PRIUS]HV Battery Block-05 Voltage(Volt)
    [PRIUS]HV Battery Block-06 Voltage(Volt)
    [PRIUS]HV Battery Block-07 Voltage(Volt)
    [PRIUS]HV Battery Block-08 Voltage(Volt)
    [PRIUS]HV Battery Block-09 Voltage(Volt)
    [PRIUS]HV Battery Block-10 Voltage(Volt)
    [PRIUS]HV Battery Block-11 Voltage(Volt)
    [PRIUS]HV Battery Block-12 Voltage(Volt)
    [PRIUS]HV Battery Block-13 Voltage(Volt)
    [PRIUS]HV Battery Block-14 Voltage(Volt)
    [PRIUS]HV Battery Charge(kW)
    [PRIUS]HV Battery Current(Amp)
    [PRIUS]HV Battery Discharge(kW)
    [PRIUS]HV Battery Fan Speed(Num)
    [PRIUS]HV Battery Power (hp)(hp)
    [PRIUS]HV Battery State of Charge(%)
    [PRIUS]HV Battery Temp 1(°F)
    [PRIUS]HV Battery Temp 2(°F)
    [PRIUS]HV Battery Temp 3(°F)
    52,878
    well done!(y)
  3. MidnightSun
    MidnightSun Junior Member
    NorCal
    Can you update on how the battery is running?
