Can Seatbelt Retractors be repaired after a collision? What needs repair/replace after accidents?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edli, Aug 2, 2009.
  1. edli
    edli Love My Prius
    Irvine, CA
    Front of car was damaged in accident. [1] Airbags and seatbelt retractors deployed. Can the seatbelt retractors be repaired/reset, or do I need to replace them? How do I reset them, if possible? If not, can I replace them with used ones? [2] Do I need to replace/repair the crash sensors (how many, where located on car?) or do they still work if they weren't damaged? [3] I'm looking for used replacement steering wheel and pssr above dash airbags (2004 model). Someone said I have to also replace the "clock springs" -- what are those?
  2. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    Re: Can Seatbelt Retractors be repaired after a collision? What needs repair/replace after accidents
    you have to replace both front seatbelts, the airbag computer , the two sensors in front, the seatbelts cannot be repaired, i mean you can free it up and live with a SRS airbag light on your dash, but there is a charge which pulls you back in the event of a collision.
    www.toyotapartspeople.com
  3. prius4ed
    prius4ed Member
    120
    Irvine, CA
    thanks for replying. I know of 2 sensors on the frame rails in the engine compartment. If those aren't physically damaged, will they still work? Are they really one time use?
