Can someone explain HID bulbs to me?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mediahound, Jan 23, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I'm admittedly confused about HID bulb wiring. Can someone help explain it to me?
    I look at pictures of ones online like below-
    but not sure how to hook them up as my existing ones do not have bare wire leads yet the picture does. I understand that all H11 HID replacement bulbs should work with my H11 HID kit however.
    These are my existing HID bulbs, there are no bare wire leads on them.
    How would I use the first bulbs in my system?
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    HID's run at high voltages, in addition to the HID bulbs- you need a ballast and step-up transformer for each bulb.
    The HID bulbs don't plug in to your existing wiring harness- the ballast/transformer plugs in where your old bulbs plug in- then the HID bulbs plug into the ballast/transformer output leads.
  3. mediahound
    903
    155
    I know this, I have an HID system. This doesn't answer why the replacement bulbs I see online have bare leads and mine (both pictured above) do not.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    If you take the H11 connector off your wires you'd be left with bare leads as seen in the first pic.
    Generic kits came that way so the leads could go in the vehicle's corresponding connector no matter what the bulb type. Definitely not as nice as getting a kit with connectors specific to your oem bulb type.
  5. mediahound
    903
    155
    Thanks. So if I get the ones in the first picture, can I use them?
  6. xliderider
    8,140
    3,278
    Honolulu, HI
    Yes, you would simply insert the leads into the oem connector, but you would need to ensure you have proper polarity, then you would need to somehow weatherproof the connections.
    You can buy the connector shells and slip the bare leads into them. Several online sites sell the connector shells, both male and female for the various types. Of course, you would be looking for an H8/H11 type connector.
  7. mediahound
    903
    155
    It appears that some HID bulbs like these:
    Have the H11 connector AND bare leads. Is that the case?
    If so, what would I do with the bare leads?
  8. xliderider
    8,140
    3,278
    Honolulu, HI
  9. mediahound
    903
    155
    Still confused.
    The last picture seems to show more wires/connectors than are needed.
    From what I understand the 2 thin connectors plug in to the ballast and the plug connector also. What happens to the bare wire leads?
  10. xliderider
    8,140
    3,278
    Honolulu, HI
    Those go to the "original" H11 connector that you unplugged from your halogen headlight bulb.
    SCH-I535
  11. mediahound
    903
    155
    I don't think that's correct. That's already taken by the ballast, which is plugged in there.
  12. xliderider
    8,140
    3,278
    Honolulu, HI
    Unless you mount your ballast right next to your headlight, you won't be able to plug the OEM connector to the ballast. That's why the HID bulbs have connectors that can be plugged into the OEM connector and pass that signal/current along to another connector to the ballast.
    Think about it. Some ballasts have the connector you want to plug into the OEM connector built right into the ballast housing. That would be very difficult to plug into a short OEM headlight harness.
    SCH-I535
  13. mediahound
    903
    155
    I understand now. The ones with bare leads need to plug into the stock H11 connector of the car.
    Ideally, the bulbs should be like this picture with an actual H11 connector and without bare leads though (which seems like a real kludge to me):
  14. xliderider
    8,140
    3,278
    Honolulu, HI
    Yes, you got it now. :D
    If you look closely at the picture in your post above, notice there are only two wires going to the HID bulb. Those come from the small connectors. The two H11 connectors are connected together by the red and black wires that pass through the rubber shield. So yes, you can plug the OEM connector directly into the ballast, and leave those two H11 connectors unused. Or use the connectors to extend the voltage/signal from the OEM connector to the ballast for easier placement and mounting of your ballasts.
    SCH-I535
  15. xliderider
    8,140
    3,278
    Honolulu, HI
    As I posted earlier, you can buy that H11 connector shell and slip those bare leads into it, making it a complete H11 connector. Just a few dollars, if it's a kit you really want, don't let the bare connectors hold you back.
    SCH-I535
  16. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
  17. mediahound
    903
    155
    Thanks, how about one showing bare leads?
  18. burstaneurysm
    469
    144
    Chicago, IL
    Same exact concept, except the green circled connector isn't there, just the bare spades.
    Honestly, I haven't seen a bare spade bulb in years.
    All that's on there is a shell that locks the spades into the connector. Otherwise you put the spades in the female H11 connector and wrap it in e-tape... any reputable kit should have a connector.
    You can buy H11 male socket shells that the spades will click into, but again, you shouldn't have to worry about it.
  19. xliderider
    8,140
    3,278
    Honolulu, HI
    Putting the connectors on those bare leads are easy, just push in from the back of the connector till they lock in.
    It wouldn't surprise me at all if some distributors stock only the bare lead bulbs and boxes of connectors, then slip the appropriate connector on prior to shipping the order out.
  20. burstaneurysm
    469
    144
    Chicago, IL
    That is incredibly likely for some vendors.
    I know the last set of bulbs I got were sealed and the box stated the bulb type and temp.
    iPhone ?
