Can someone help me identify this part.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr_Desmond, Jul 5, 2016.
  1. Mr_Desmond
    Mr_Desmond Junior Member
    17
    36
    Missouri
    I was changing the cabin air filter in the prius today and when I took out the glove box this thing came out. I am not sure what it does or where it goes... 1467696141449.jpg
  2. JC91006
    16,929
    8,639
    It goes on the right side of the glove box, it's to provide the glove box with a little support do it doesn't come crashing down when you open it
    Burna J and xliderider like this.
  3. Mr_Desmond
    17
    36
    Missouri
    Thank you! I got it now. I feel bad making a thread for this..
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yeah, it's like a mini gas strut, but it's not pressurized.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Feel good about the thread. It reminds the rest of us to watch out for that part when we check our filters. ;)
  6. bisco
    52,750
    that piece is a pain in the neck.
    Rebound likes this.
  7. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Even worse is being careful not to break off the little plastic stud it fits on.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Threads are free. We will just make more, we won't run out. What will happen is that we will get side tracked and before you know it your thread will be discussing things no normal human ever wondered about. :)
    (Now making the same thread in multiple forums, THAT we get grumpy about!)
    Rebound likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    ROFLOL! I've noticed that. Guess that's why I still hang around. :ROFLMAO:
    Re: the original post. Mine never fell off, but I have forgotten to reattach it a time or two.
  10. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    One half of the stud on the side of my glove box started to come off, not totally, just enough to allow the "piston" to slip off by itself. I tried to repair it using a pencil eraser and some glue, to no avail. Now I just leave the "piston" hanging from the non-glove box stud and remember to carefully open the lower glove box. No big whoop - I'll take another stab at it once the weather warms up. Bad design...
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Try to find a replacement glove box lower from a wreck
  12. RRxing
    2,562
    1,839
    NEPA
    I can live with this...
    Rebound likes this.
  13. Mendel Leisk
    42,237
    Remove the original post, drill a hole through at that location, and install a bolt with locknuts both sides, to act as a pin? Just a thought. Would look kind of funky though.
    #13 Mendel Leisk, Feb 8, 2017
  14. RRxing
    2,562
    1,839
    NEPA
    I was thinking about that - Something I might do once the weather warms up...
