Can Someone Please Put Together A Simple LED Up Grade Chart?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Fore, Sep 25, 2012.
  1. Fore
    Fore Don't look back!
    494
    106
    Just too many forums on LED conversions, which ones work which ones don't, brighter, yellow, dimmer etc. etc... Can someone please just fill in the blanks below on which LED's works best for each one and where to get them. Thanks!
    2010 Toyota Prius LED Conversion Size:
    Low Beam Headlight Bulb Size:
    High Beam Headlamp Light Bulb Size:
    Parking Light Bulb Size:
    Front Turn Signal Light Bulb Size: Rear Turn Signal Light Bulb Size: Tail Light Bulb Size: (LED Already)
    Stop Light Bulb Size: (LED Already)
    High Mount Stop Light Bulb Size: (LED Already)
    Fog/Driving Light Bulb Size:
    License Plate Light Bulb Size:
    Back Up Light Bulb Size:
    Front Side Marker Light Bulb Size:
    Map Light Bulb Size:
    Dome Light Bulb Size:
    Step/Courtesy Light Bulb Size:
    Trunk/Cargo Area Light Bulb Size:
    Jin and Steve Gibson like this.
  2. Fore
    494
    106
    Well guess not! Thanks for all the views tho.
  3. 1ULV2H8
    1ULV2H8 Member
    66
    25
    Columbia, SC
    I would like to see this condensed, too. Hopefully someone will chime in with info.
  4. Blizzwhiteprius
    Blizzwhiteprius Junior Member
    38
    35
    Seattle, Washington
    Low Beam Headlight Bulb Size: h11
    High Beam Headlamp Light Bulb Size: 9005
    Parking Light Bulb Size: 2825
    Front Turn Signal Light Bulb Size: 992 (7440A)
    Rear Turn Signal Light Bulb Size: 992 (7440A)
    Fog/Driving Light Bulb Size: h11
    License Plate Light Bulb Size: 2825
    Back Up Light Bulb Size: 7440
    Front Side Marker Light Bulb Size: 2825
    Map Light Bulb Size: 168
    Dome Light Bulb Size: DE3175
    Step/Courtesy Light Bulb Size: 175
    Trunk/Cargo Area Light Bulb Size: DE3022
    For the interior Lights I used the kit from Exled I am very happy with them but they are a little pricey. ​
    Lamp Replacement Guide View All Bulbs
    samius, calirider, Jin and 2 others like this.
  5. Larsenvega
    Larsenvega Junior Member
    36
    16
    Tucson, AZ
    I bought all of my LED lights from Amazon.com and got free shipping. All together, it cost me $28.20.
  6. xliderider
    xliderider Senior Member
    6,588
    2,358
    Honolulu, HI
    Bulb sizes are readily available from websites such as Sylvania.com.
    LED conversion kits are easily found on eBay for the interior lights, except for the vanity lights.
  7. Fore
    494
    106
    Thanks so much for all of your inputs. (y)
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,273
    Palmdale, Ca
  9. Steve Robinson
    Steve Robinson Junior Member
    36
    43
    Mississauga, ON, Canada
  10. Danger
    Danger Member
    175
    22
    Frisco
    Please post link to the led lights.
  11. Chunker
    Chunker My name is Chunker...I wear a hat
    71
    I have the exLED ones as well and I prefer them over the ones I got from precisionled.com. I like exLED ones more because they are way brighter than the ones precisionled.com sent me.
Loading...
