Can the battry fan be wired to a manual switch?/ Fan controller testing?
Discussion in 'Gen 2 Prius Main Forum' started by WadeM, Sep 27, 2021.
  1. WadeM
    WadeM New Member
    Massachusetts
    My battery in a 2005 Prius gets hot quick to 120+ and I'm in a hot climate. I'm thinking of wiring it direct with an on/off or variable switch that I control. Has anyone ever done this and would there be any issues giving it the full 12-14V from the auxiliary battery?
    Maybe better would be to test the fan controller. Can anyone advise me?
    The fan works and I have cleaned it.
    Thanks!
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You can turn it on with several apps, no need to add a switch. Search the forum and you will find the answer.
    49,492
    scangauge for one
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,916
    Columbia, SC
    or Hybrid Assistant
    I think direct wiring 12v to the fan would be a mistake. Pretty sure it would let out all the magic smoke if hit with 12v from a 'stopped' condition.
  5. ChapmanF
    15,618
    Pretty sure that's how you bench test it. That, and grounding the SI input. Smoke stays in, I think.
