Featured Can the height the hatch opens be controlled?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Carol DiPirro, Jul 8, 2017.
  1. Carol DiPirro
    Carol DiPirro Junior Member
    25
    47
    New Hampshire
    I got my new Prius Prime home and opened the hatch in the garage and it touched the door!!! I looked in the manual and googled it, but is there anyway anyone knows of controlling how high the hatch opens?
    Thanks!
  2. bwilson4web
    16,531
    For now, twine. I am not aware of a Toyota supported option to limit how far the hatch moves.
    I would probably look at an aircraft grade, stainless steel cable with loops at each end and swagged for the exact length. You'll need a quality machine shop or airport mechanic to make the part. Better still, visit an EAA meeting and ask for help ... bring cookies.
    #2 bwilson4web, Jul 8, 2017
    pilotgrrl likes this.
    52,839
    i glued foam to my garage door.
    bwilson4web likes this.
  4. Tideland Prius
    16,678
    I back into the garage so it clears the door.
    bisco and bwilson4web like this.
  5. Trollbait
    12,822
    Bungees
    pilotgrrl and bisco like this.
  6. mikefocke
    4,079
    1,862
    Sanford, NC
    Swimming pool noodle cut in sections and attached to the inside of the garage door. Contact made, no harm, no foul.
    pilotgrrl, bisco and Raytheeagle like this.
  7. bisco
    52,839
    if i did this, i would inevitably drive out with the hatch open.:cool:
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I would probably put in reverse out of habit :eek:.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Here's what I did for our new RX450H:
    The nice thing about the 450H is it has 4 preprogrammed settings for hatch height opening ;). Setting 1 was too high, so we have it on setting 2:).
    Not sure what the Prime has, but that is a nice feature. I did the pool noodle route as added protection, cause eventually the 12 volt will get disconnected and the settings will default and I'm not sure if this is one that will default (probably will).
    I fell two noodles short of getting the hole door done(y).
    Prodigyplace and bisco like this.
  10. Prodigyplace
    12,712
    11,848
    Central Virginia
    That's using the old noodle! :LOL: :D
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Especially since they just happened to be "lying around"(y).
    Prodigyplace likes this.
  12. 3PriusMike
    3,101
    2,421
    Silicon Valley
    That sure is using your noodle. :)
    (Now I see someone beat me to this comment)
    Mike
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I would hate to see what it would cost to repair the 450H :eek:. Just glad they were around and available.
    Hope you are doing well. Where are you at on the Model 3 list?
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I'm guessing a year away...
    Mike
  15. hill
    9,032
    Me too - but then it hit's our fluorescent-looking LED tube light fixtures
    on the other hand, our new car has sensors on the hatch, so it'll only open so far as it deems to be close enough. Then, i sometimes bump my head on the partially open lid, trying to walk underneath it. Ah, the trials of living in the 21st century
  16. Tideland Prius
    16,678
    That's a low ceiling! Our garage ceiling is 10 feet tall.
  17. hill
    9,032
    Ours is 8' high - pretty much standard around here. Lights hang below that 8'. Maybe my 6'-5" has something to do with it?
    I'd show off the knots on my head but it's not a pretty sight.
    #17 hill, Jul 12, 2017
    pilotgrrl and markabele like this.
  18. Tideland Prius
    16,678
    Yeah you're too tall :D. Yeah I can lift the Prius hatch (2nd, 3rd, 4th gen) up and fully open and have plenty of clearance (our light is a round, flat-faced dome-type light so it doesn't protude too much, probably the 1/2 the depth as your fluorescent)
  19. bisco
    52,839
    the knots become more obvious after your hair falls out.:unsure:
    Trollbait and Prodigyplace like this.
  20. ETC(SS)
    7,539
    I'd be tempted to remove one of the struts (I think that the geek term is 'lift support") and see if you can find one whose stroke is an inch or two shorter.
    There's probably already a non-OEM replacement part for the G4/Prime whose specs are known (i.e. 10" 40#) and usually the college grad student working at the auto parts big box store will let you try one before you buy it - or even help you replace it.
    If you find a strut that reduces the hatch swing by just a few inches then you can share the data with your fellow cave-dwelling........'prime'mates. :D
    pilotgrrl, RCO and Prodigyplace like this.
