can the pip charge with the a/c on?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ramattos, Aug 1, 2012.
  1. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    i am thinking of upgrading to a pip. i work in my car and was wondering if i plug it in can i still have the a/c running while it is plugged in or not? i read somewhere that if you turn the car into ready mode the systems wont allow it
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    No, that would require more than 11.6 amps that the 110volt charger device draws, so while using the remote A/C function of the key fob the charging of the battery stops while the A/C is running.
  3. Right, while it is charging, one cannot put the car in ready mode. Although, after fully charging, you could set the AC to 76-78 and I believe this charge would last quite a while. In the order of 15 - 30 minutes ( a guess ).
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    You can use the remote A/C on the key fob to turn on the A/C when the pip is plugged in and charging, just that the charging session will stop untill the A/C has finished running.
    HillCountryEVer likes this.
  5. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    So, you can precondition the car for 10 min and then let it charge back for another 15 min? Can you pre heat the car in winter?
  6. markabele
    5,084
    1,782
    Nebraska
    I would think you will get pretty much back to outside temps if it is not on for 15 min.
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    No, the remote AC wont work when the outside temp is too low (something like 65 degrees or so). It also wont work if the interior temp is lower than the outside temp. It really is there to just cool the car down on a hot day.
