Can the Prius wagon hold 4 foot x 8 foot pieces of plywood, or if not, tow a trailer that can?
Discussion in 'Prius v Main Forum' started by SBCA_CA, Dec 31, 2019.
  1. Offline
    Offline Active Member
    644
    237
    Lenexa, Kansas
    The OP said: "As far as material delivery, I don't think so." Where do live that lumber yard deliver for free?
    If the land is rural, it's often not practical to have large loads of unused lumber sitting on site unless someone is always there to guard it. Even when a house is going up, thieves will come in and rip out stuff. After I had a house built in a rural area 40 years ago, I tried to help others by driving away material thieves from nearby houses that were under construction. Usually it was enough to just drive up to the thieves parked vehicles and make sure they saw me taking photos of their license plates before I drove away. I tried not to confront them - too dangerous - and sometimes it was in the middle of night. It was sad - especially when I saw guys with their children with them stealing stuff.
  2. SBCA_CA
    SBCA_CA Junior Member
    30
    The land will be rural, and there will not be people there to guard large amounts of delivered materials.
  3. frodoz737
    frodoz737 Top Wrench
    4,702
    2,500
    33
    1/2 ton PU.
  4. Mendel Leisk
    41,504
    It recently took me three trips to get the complete wet/dry vacuum, hoses and nozzles over to our daughter's.
  5. SBCA_CA
    30
    Oops. Damn senior moments.
  6. bisco
    51,988
    boston. very competitive. if youre building a house, it's all free, even small emergency deliveries.
    Johnny Cakes likes this.
  7. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Not in a Prius; it's the two electric motors and some gears. No belt.
  8. Will N
    Will N Junior Member
    Southern California
    2014 Prius v wagon
    I've hauled a lot of plywood with my Prius V. On the roof. I have a roof rack for kayaks. It's not flat, I've got fittings to cradle the kayak so the plywood is uneven, no problem. I've also hauled lumber and stuff for years on a variety of vehicles.
    A rack is okay, but not necessary. A moving blanket to protect your paint is more than enough.
    The biggest issue is tying down the load--and this is the most serious issue.
    For my kayaks and for hauling plywood and lumber the most important tie downs are the front and rear. Plywood or any sheet goods will catch the wind and try to lift off. This is a powerful force.
    All Prius's have no good tie points in the front of the car. To get around this, open the hood. You'll noticed two fender bolts on each side. Remove the front one. Get some webbing, 3/4 or 1" thin is good (I use old roof tie down webbing) about 12" will do, double it and on the open end use a soldering iron or a hot nail in pliers to burn holes for the fender screw. You don't need new or longer screws. When you screw the loops in you can have them stick out the sides of the hood, or you can tuck them underneath. These make reliable strong tie points.
    I usually tie an arc across the two hood loops and then run two ropes towards the back to keep the front of the plywood down. At the back there's one tie underneath. Good enough. Across the two rear doors, windows open I tie a rope around. I put the rope through the open windows instead of closing the door on the line. When you jam it in the door frame you can cut into the rubber seal.
    If you have any doubts after you start driving, pull over and check everything. It's easy for knots and rope to slip.
    For lumber I usually tilt back the front seat, remove the head rest, back seat down of course. Make sure if it shifts it doesn't cause an accident or go through the windscreen. If you go for a roof rack, those cheap ones with the board and rubber suction cups, if properly attached are as good as any $400 Thule/Yakima rack. Hope this helps. If this sounds good but my description is not understandable, let me know and I'll post some photos.
  9. SBCA_CA
    30
    As much as I appreciate your detailed description, because I cannot be certain that I could fully cancel out/block the lift from carrying large items on the roof, I'd rather put the items in a trailer. The lift is a dangerous thing, as lift also reduces steering effectiveness.
    ice9 likes this.
  10. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    I've hauled plywood sheets cut down to 2 x 8 in the Prius cabin. Very awkward tho, and not recommended if you are doing it on a regular basis. Using a roof carrier, as SBCA_CA describes, is the way to go. Wish I had thought of that at the time.
  11. rjparker
    rjparker Tu Humilde Sirviente
    10,165
    6,319
    Texas Hill Country
    #31 rjparker, Jan 2, 2020
  12. MVPLRJohnson
    MVPLRJohnson Junior Member
    26
    Manchester, WA
    2013 Prius v wagon
    The Torklift 2” hidden hitch and the Detail K2 utility trailer and you are set! That’s my set up.
    Take it slow and safe with larger loads and you’ll be fine.
  13. George W
    George W Senior Member
    911
    514
    San Antonio
    I know this isn't the same, but I have fit 40" wide planks in my Gen 2.
