Can the top DRL housing fit a 9 way led? or just 5 way?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by waiwaiet, Jul 12, 2011.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Great. Which bulbs did you go with (links)?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Got it.
  3. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    got two 9led for side parking and two 5led for above headlight, cant wait to get those and start working on it!
  4. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    I replied to your other post.... yes the 9-way LEDs will fit just fine and clear the headlight glass.
    They're bright, better than the 5-way LEDs but not really visable under direct sunlight. At night they're fine.
    I also tried 25-way 194 LEDs in there and you can make them fit, but they'll be slightly touching the glass (no heat, no discoloration from my tests), and those are much brighter. You can see them during the day in direct sunlight and they are very bright at night.
