Can UOA disprove oil change claim
Discussion in 'Newbie Forum' started by BK2016eco2, Sep 22, 2025.
  1. BK2016eco2
    BK2016eco2 Junior Member
    Iowa
    Four Touring
    Hi guys - I wasn’t quite sure where to post this, so I figured the newbie forum would be the safest bet.
    I just finished working on a very good friend’s car who has a receipt from a shop showing he was charged for an oil change that occurred less than 1000 miles and 6 months ago.
    From the look and feel of his oil, which I just changed for him (Valvoline R&P 5W-30). I can guarantee you this shop did not change the oil or the filter. The oil was black as I’ve ever seen any oil, was thinner than 0W-8, and the filter had numerous visible particulates in nearly every pleat. The car manual calls for 5W-30 btw - and the difference between what came out and what went in was noticeable to say the least. Also notable is the fact that the oil filter was a cartridge style, the cap for which had been torqued down to such an extent that my impact driver, which is capable of 140 lb.ft of loosening torque, had zero effect loosening the housing cap.
    I’ve kept the oil and the filter, but I have no idea how one would go about proving whether or not a shop had done the work that they said they did in this situation. The only thing I can think of is a used oil analysis - would it be possible for Blackstone or SPEEDiagnostics or any other company in the UOA space to disprove this shop’s claim to have changed the oil?
    I understand that definitive answers are probably not realistic, but any input is always appreciated.
    -BK
    52,891
    i think it would all be more trouble that it's worth. best thing is a bad yelp review, or threaten them with one and ask for whatever it is that will make it right.
  3. Mendel Leisk
    42,373
    Oil can get quite dark, quite fast. Just to be on safe side, another oil change doesn’t hurt, and just move on. It’d be really tough to prove anything conclusive, and the onus is on you to provide the proof.
    I wouldn’t give them any “bad press”, it’s possible they did what they claimed. It’s also possible they didn’t, but do you want to smear a business when it’s not for sure?
    what’s the car in question, btw? A Prius of some ilk?
    #3 Mendel Leisk, Sep 22, 2025
    douglasjre and PrimeDan like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    This is a common problem with the disaster design of the Gen3 cartridge style oil filter. They didn't think through the fact that universal kits that oil change shops use for these cartridge filters looks like something you'd want to attach to an air power impact driver. And no big deal doing that taking it off. But it has created misery for so many of us who have to take one off if the minimum wage worker used an impact driver to put it back on. I highly recommend everyone replace that oil filter mount with one that accepts the exact same screw on oil filter used in Gen1, Gen2, and Gen4 Prius. And I hope Gen5 uses the same oil filter!
    #4 PriusCamper, Sep 22, 2025
    PrimeDan likes this.
  5. BK2016eco2
    Iowa
    Four Touring
    Bisco - as a business owner, I generally don’t put out bad reviews about other businesses without first addressing the issue with them - They can’t fix what they don’t know is broken -
    I always approach them respectfully - without asking anything to “make it right”, and wait to see if they’ll see the opportunity to turn a negative experience into one I can promote with positive word of mouth. Every business owner I’ve done this with are thankful when they don’t feel attacked, and has never led to an escalation where I’ve felt it necessary to inform other consumers of the business as a bad faith actor.
    That said - the notion of this oil change having been done is one which I absolutely cannot imagine to be true. The vehicle is a 2nd one kept as a cheap insurance policy in the event something should go wrong with his primary transportation, and I wholeheartedly believe the owner’s claim that it hasn’t seen more than 1000 miles since the “oil change” occurred. I called the shop personally to confirm the receipt’s information to be true - I wanted to hear it from the horse’s mouth - and did.
    However - a “he said, she said” situation isn’t one worth slinging accusations over, as Mendel has rightly pointed out. But - if it were possible to get irrefutable data confirming my position - I would absolutely pursue that endeavor to bring it to the attention of the owner. Out of principle - I will never condone this type of shady practice from someone professing to be a mechanic - inherently deserving of trust in ways that can have catastrophic consequences when that trust is violated. An $80 UOA is well worth it to me if it allows me to call out that violation with irrefutable data provided by an impartial third party. I will take this route 100% of the time - not to get litigious about it, but out of principle.
    Mendel - the vehicle in question is a 2010 Chevy Equinox. It isn’t remarkable in any way - there’s no fiscal justification for my blood to boil, but I’m not going to pretend that it isn’t. The man lied to me, he’ll have a chance to acknowledge that mistake when confronted with evidence (if said evidence is possible to obtain), and it’ll be up to him how the situation unfolds after that.
  6. BK2016eco2
    Iowa
    Four Touring
    Also - I should have mentioned that a UOA is primarily being pursued out of a need to make informed decisions going forward. If it returned information pointjng towards an imminent catastrophy, it wouldn’t make sense to replace the front brakes, calipers, or rotors (hypothetically). If the oil was just blackened due to some series of events that I didn’t know could lead to that result (to be fair - is a possibility) than I learned something. Or, If the cause of the oil’s condition was harmless and inconsequential - than maybe I advise that the additional investment to fix the brakes is fiscally sound.
    It’s more about informed decisions at this point - but I’m also hoping it’ll be a weapon allowing me to confront the issue.
    Without any sort of evidence that substantiates my claim, I don’t get to address it… and I suppose this post is me attempting to manage my expectations.
  7. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    UOA can tell you if the additives in the oil have been depleted- they'd report the TBN counts that help keep the pH from going too low with time and fuel combustion exposure.
    Thing is, it's not irrefutable, not by a long shot. You'd pretty much have to run more of the same oil through the same engine and get more analyses done at diffrent points in time to have some data to compare against the sample you have now.
    It could be informative. It won't be positively conclusive. It will take a lot of time and at least some money. Is that really worth it in the context of where to get future oil changes for a 15 year old Chevy?
    #7 Leadfoot J. McCoalroller, Sep 23, 2025
  8. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    Honestly I’d just have them take it somewhere else for the next one or DIY and compare how it looks after 1,000 miles. The odds of getting 2 different places to not do it and say they did in a row are astronomical IMO. If it looks the same this next time, it’s just how the car is. If it’s a lot cleaner, then you don’t ever go back to that shop again.
  9. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    It's been 6 months and 1K miles; that's going to be difficult to prove - considering mechanic could've used thinner winter oil.
    Go someplace else and check their work next time. It's not that difficult to pull the dip stick and check oil. The time to complain is when your leaving the shop or next day at the latest.
    FWIW, those newer 4-banger GM engines does NOT handle missed oil changes very well......
  10. bisco
    52,891
    how do you prove the used oil came from that car?
    PriusCamper likes this.
  11. PriusCamper
    13,475
    5,440
    Not sure why this is still worth discussing? If you have a problem with a sketchy oil change place and you don't bring it to their attention right away then it's no longer the oil change place's problem.
  12. BK2016eco2
    Iowa
    Four Touring
    bisco - when I checked the dipstick, I knew fuckery was afoot and began taking footage of key moments. One of those moments was when I pulled a midstream sample during the drain, which I sealed with masking tape wrapped around the lid of the container and my signature written in the opposite direction that the tape was applied. It would be impossible to break that seal, manipulate the sample, and reseal it in a manner that my signature would still line up seamlessly.
    Biomed01 - your point is well taken, and I’ve made sure my friend has a much better understanding of his vehicles now. This still doesn’t absolve the individual who said he provided a service, charged for said service, but didn’t actually do it. It’s one thing to tack on an extra hour or two of labor if he felt the price was justified, it’s quite another to charge for a service that was never provided, let alone one which involved one of if not the most critical elements of the engine. It isn’t as it said service was for windshield wipers or for “cleaning the MAF sensor” - a little white lie with little to no consequences. This lie caused an engine to run on very little oil that was badly damaged.
    The point - he could have padded the check any number of ways - he knowingly chose a way that he knew had a very high likelihood of causing that engine to die.
    PriusCamper - you aren’t wrong - but neither am I for being pissed off about the situation.
    At any rate - I’m happy to let the discussion die here, unless anyone wants an update once the UOA results are in.
  13. PriusCamper
    13,475
    5,440
    Most important is your friend's car... I'd change the oil again after 1000 miles and just before you do that run an engine flush in it for a minute or two... Also on used Prius with really thick non-synthetic oil I've found that switching to full synthetic can accumulate more dirt and debris after a 1000 miles (clean out engine) compared to just going with regular oil. There's probably something in the chemistry to explain why that is...
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    A similar situation happened with my young son's car. He had the oil and filter supposedly changed at a major service company, G***year, and one month later I looked at the oil on the dipstick. It was so black I couldn't believe that it was changed recently.
    I'm almost positive he didn't check the dipstick after the oil change, or I would have told him to take the car back and have them do it for real.
    I ended up changing the oil and filter, and installed a Fumoto valve in place of the drain plug. I had also bought my sons (twins) a jack, some jackstands, and all the necessary supplies to start doing their own oil changes.
    Showed them the entire process. They live in another state, and I was there to do other maintenence on the cars. We'll see if they start doing their own oil changes, the 6 month mark is coming up next month.
  15. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    just to throw it out there, I've seen absolutely horrible-looking oil come out of a Chevy with a leaking fuel injector barely 1,500 miles after an oil change that was not in dispute.
    Double check that the car is actually running right.
  16. PriusCamper
    13,475
    5,440
    I've known really cheap motor oil to get dark way faster than high quality synthetic...
  17. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Cars is Cars (isn't that a bastardization of some sort of baseball saying??...seriously...if someone knows, let me know).
    I have had cars where when changed after six months the oil looks as clean as the day I poured it in (my Prius comes to mind). And have had cars where a week after I changed it, the oil is black. Some oil blends can get pretty dark within a few hundred miles. Does not mean they are not effective.
    Move on.
    Kris
