CAN-View Data Analysis, Complete with Charts
Discussion in 'Gen 2 Prius Technical Discussion' started by JimboK, Jun 2, 2008.
  1. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Nice work guys, keep it up!
    Rob
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I'm not following this thread as closely as would be ideal; I was
    on the road all last weekend and still catching up on stuff.
    However, Jimbo pointed me over here for a couple of comments.
    I can't really say much about the injector time -- I was asking
    about the units too, and all my Autoenginuity hands me is already
    translated into milliseconds. But Bob is correct in that the
    ECU keeps reporting some small value like 1.6 ms even after
    the engine has shut down. Remember, this is also what was giving
    the Scangauge fits as far as fuel calculation! So that's likely
    your rarely-goes-to-zero issue. Now, I don't know how you're
    collecting figures on fuel flow, since that too would be dependent
    on calculations done off injector timing -- there is no actual
    flow meter in the Prius fuel system, and what this implies is
    something I always find mildly bothersome: all those calculations
    are wholly dependent on fuel PRESSURE from the pump, because that
    governs how much you're going to squirt. Which there's no way to
    measure. If fuel pressure were lower than stock you'd likely get
    longer injector times to maintain a stoich burn, which would probably
    show up as abysmal MPG averages in the car. In fact I'm not sure
    how, if at all, Toyota corrects for this in the event that fuel pumps
    and the in-tank regulators start aging, wearing, and maybe delivering
    differently over time. This is another reason it's so important to
    keep collecting those external averages, and hope like hell your gas
    station pumps report accurate quantities. [As the price thing
    spirals out of control, that comes under question and there have
    already been a few gouging incidents reported.]
    As to the current-vs-speed thing -- someone had to remind me of
    this over on PTS a while back too: POWER is force * velocity, and
    is also torque * RPM. If you want to exert a constant pushing
    force on the car [torque at the wheels], power demanded is going
    to rise as speed does. Now, the battery under load is essentially
    a constant-voltage device, and POWER is also volts * amps. Thus
    as speed increases and demand for power to continue accelerating
    ramps up, so does current, even though your foot hasn't moved.
    And if voltage starts to sag, you need even more current!
    Recently I've been chasing how to exploit some very minor changes
    I see at my vacuum gauge over a variety of car speed and engine
    RPM, implying different settings of the throttle flap. Most notably,
    the RPM point at which the engine appears to get under "full load"
    and nominally high torque seems to vary quite a bit with speed.
    To a certain extent, it seems like playing around down in low RPM
    regions like on the order of 1200 seems to return reasonable speed-
    maintaining push at high instantaneous MPG -- not SHM as Dan et al
    described it, but something a little higher on the scale and possibly
    similar to those very low-RPM DWL scenarios that the Insight guys
    strive for [well, except that we don't have lean-burn]. It vaguely
    follows up on some of the throttle-vs-RPM stuff I posted under the
    "vvt" page, where I see a clear vac drop around 2500 RPM on the
    highway, but this is more subtle stuff at the low end. I have no
    particular results to report from this yet but first I have to
    determine what data to collect to start making some charts from.
    I want to try and avoid the problem of the scantool reading parameter
    A under one operating scenario and then a while later reading
    parameter B right after everything's changed, yielding a bad mismatch
    in data. The only way that's going to be avoided in any pure way is
    to get the car on a dyno so we don't have to deal with traffic.
    See, three years of ownership, and I'm *still* learning how to drive
    this car.
    _H*
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Finally got it done. This is from the commute this morning to my part time job site. I'll see if I can get posted later the same charts as those from the full time ride, with annotations. It's a totally different route in more or less the opposite direction and through the middle of an urbanized area. But for now this shows the relationship between current and speed for neutral glides.
    The Y axis on this has the opposite orientation as that of previous charts showing glides. Curiously, N-glides sometimes show positive current flow (more on that below) so I plotted positive values. Then it seemed more logical for numbers to increase going up the Y axis rather than down. Maybe I'll redo the previous chart later to make the Y axes match.
    As stated, current flow moves within a more narrow range than with pedal-controlled glides, at speeds below 30 MPH. Interestingly as speed approaches 30 it appears to creep up a bit, and then above 30 it's all over the map. Finally, what's most interesting to me is this blip:
    This is a neutral glide that I let transition to warp neutral coming down a fairly steep bridge approach. It carries me across the bridge and then up a short incline to a toll booth, where the last data point is.
    On this and other steep hills previously I've noticed a brief surge of positive current at speeds around the mid-30s, often spiking to well over 10 amps, along with a simultaneous sensation of increased drag as though I had let it slip into regenerative coasting. (It might have been over 10 amps here too but CAN-View captures data only every two seconds or so, and that's about the duration of the positive current flow.) Then something I hadn't noticed before are the fluctuations of current flow in warp neutral being more erratic than most of those at slower speeds.
    So, once again calling upon the experts: What explains this change in current flow above 30 MPH, especially the blip, while in neutral?
  4. bwilson4web
    16,537
    Very interesting! I have not seen that with my NHW11. However, I'll go see if I can reproduce it soon. But I don't understand quite understand:
    "... neutral glide that I let transition to warp neutral ..." did you slip the car back into "D"?
  5. JimboK
    2,817
    190
    49
    Chesterfield, VA
    No, I keep it in neutral going downhill to avoid the ICE spin-up as the car crosses the 40 MPH threshold. Warp neutral is a term Hobbit uses (and may have coined) presumably to make the distinction between this and warp stealth.
  6. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Done. The test consisted of four runs with each method on a four-lane road through a lightly traveled industrial park. The route is shown here. There was a net elevation decrease of approximately 36' from start to finish.
    I aimed to begin each run at approximately 28 MPH. Each glide was allowed to continue to a defined ending point 0.6 mile from the starting point.
    Outside air temperatures were in the low 90s, and winds were out of the WSW at around 15 MPH -- both as reported by Weather Underground's almanac information for zip 23832.
    Both front windows and the right rear window were opened for driver comfort and ventilation for the hybrid battery. Climate control was off to avoid the significant current draw from air conditioning.
    Results, with charts for speeds and hybrid battery current flow:
    As suspected, there clearly is more drag with neutral glides than with pedal-controlled glides.
    The CAN-View data capture records battery SOC in half-percent increments. All glides began with SOC between 55.5% and 59%. SOC predictably dropped more with PC glides than with N glides: 1%-1.5% with each of the former and 0%-0.5% with each of the latter.
    I will probably post these results in a new thread, with added discussion, for the benefit of the P&G regulars.
  7. bwilson4web
    16,537
    I see 5*200 -> 3*200 watts of pedal thrust. This is roughly 1.3->0.8 hp of additional thrust.
    Graphing tip: make the data points 'unique style' when comparing two or more different experimental protocols. For example:
    • lines w/o data point markers - one style
    • lines with large filled data points - second style
    • lines with large empty data points - third style
    • lines using "+" data points - fourth style
    Also, my tired eyes see 125% scale charts much easier than 100%.
    ps. Excellent data! I like this!!!
  8. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    What is the difference in kinetic energy of the car at the end of the run, between neutral and pedal controlled glide, in kWh?
    What is the difference in energy used from the battery during the run, between neutral and pedal controlled glide, in kWh? (including the generator and battery inefficiencies)?
    In other words, which method has consumed less energy, and is therefore more efficient?
  9. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Thanks for the quick calculation.
    I'm trying to get a handle on your formatting suggestion, but it's not quite sinking in. How specifically might you have done this one differently?
    I'll work on enlarging the charts a bit. I've been taking the path of least resistance -- simply pasting into Paint and saving as a JPG file.
    Unless I'm missing something, it seems to this somewhat uneducated mind that with the lower current flow, N-glides are more efficient. It seems generally accepted that use of battery power and subsequent replenishment introduce inefficiencies from conversion losses, and better from an efficiency standpoint is to avoid the battery as much as possible. I can't quantify it, however, beyond what the charted data show. (Well, maybe I can, but I can't put my hands on that spreadsheet at the moment -- must have left it on a different computer.)
  10. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I think it would be better to get a calculation back to getting the SOC back to equal. This would be a better. On a level surface it will take additional pulse time to get back the lost SOC which is not as efficient as not using the SOC in the first place.
  11. bwilson4web
    16,537
    Jim,
    You are doing great! I'm just offering some style stuff, some polish:
    Use 745 watts ~-> 1 hp. For calculations, I used 200 VDC for the traction battery voltage although in real life, it varies. But for a first order magnitude, back of the envelope, rough guess, it works.
    Click on a line and use the "Format" pull-down to change the line formatting. This allows changing the data point indicator so you can change the size, fill, shape and color. The trick is to use a common style for one independent variable and a different style for the other. This is just an example of how to overload a graph with a lot of independent sets of data:
    BTW, I use the same technique for making my jpeg files. However, I like to use 125% 'zoom' so my tired eyes can read the fine detail.
  12. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Yes, I'm familiar with the mechanics of changing line and marker formatting. I was curious how you might have chosen to reformat mine. I'm always open to suggestions for improvement.
    My first goal in formatting these most recent charts is to provide a quick at-a-glance visual of overall trends. Then by varying the colors and marker styles, folks can distinguish between individual runs for closer inspection.
    Increasing the zoom level in Excel, or either the zoom level or image size in Paint, didn't change the size of the finished file. Maybe I need to learn a more sophisticated image editing application -- an area I haven't spent much time with.
  13. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Another test completed yesterday and today, this comparing MPG results using the EV switch with those not using it. These are from my morning commute (described in detail in post #5 above) the past two days.
    Many of the PC regulars insist that the EV switch's benefit is marginal at best. My own experience suggests otherwise, but I wanted to document it with a (semi-controlled, at least) test. The main argument against its use is that depleted battery energy has to be replenished, with conversion losses suffered through discharge and recharge. But my main use is not for propulsion, but instead to force ICE shutdown during its warmup when propulsion is not needed.
    Nonetheless, I sought to control and account for SOC. Though the goal is not to propel the car on battery power, ICE recharging is lost with EV mode. Therefore, I attempted to begin and end each run with identical SOC. The non-EV run was on Monday, and I simply began and ended it with what the car gave me: 54% to begin and 59% to end, both as displayed by CAN-View. Initial SOC Tuesday was 56%, so on first startup (with EV activated) I ran the AC until the display showed 54%, at which point I began data capture. SOC was displayed as 60% as I approached work, so I ran with a short EV mode segment to bring it down to 59%. Turns out, the recorded data showed the EV run beginning at 54.5% and the non-EV run at 53.5%. More on that in a minute. The data showed ending SOC for both runs to be 59%.
    I determined from the data the "SOC equalization" point where SOC from the EV run had climbed to match SOC from the corresponding point on the non-EV run. It is at that point that I consider the MPG difference to be most meaningful -- whatever battery energy was used for EV mode has been replenished. I adjusted for the 1% startup difference in defining the equalization point: it was where 60% for the EV run matched or exceeded 59% for the non-EV run.
    I noted cumulative trip MPG at each of 5 different benchmark locations, including destination. As luck would have it, the SOC equalization point fell very near benchmark #3 for the EV run, with that benchmark for the non-EV run lagging by about a half minute. So I use that benchmark's numbers for my results comparison: 73 MPG with the EV switch versus 69 without. Given that the EV run was on the cooler of the two days, the MPG difference is even more significant. Wayne Brown's simulator predicts a 2.3% improvement in fuel economy at 22 MPH with an increase in OAT from 60F to 65F.
    22 MPH, BTW, was the combined average speed of the two runs up to the equalization point. Other average speeds:
    • EV run, up to SOC equalization: 23.1 MPH
    • EV run, total: 22.0 MPH
    • Non-EV run, up to SOC equalization: 20.3 MPH
    • Non-EV run, total: 20.7 MPH
    Skies were clear both days and winds calm or nearly so.
    This also will probably find its way into a separate thread with added discussion.
  14. bwilson4web
    16,537
    Jim,
    You have the data to show how much energy is added to the battery, the SOC, from the self-discharge in the morning. There is another thread about charging our batteries. You have the data to calculate how much it might help.
  15. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Not sure I remember seeing that one. Do you have a link?
    Back to the EV mode tests ....
    After that post, something in the charts jumped out that bothered me a bit. The non-EV run had three complete stops at red lights before the second benchmark. To find them all red is typical. But on the EV run I got lucky, in a sense, catching two of them green. So not having to completely stop could have biased the results in favor of the RV run.
    So I repeated the EV run this morning. OAT was closer to that of the non-EV run: 64F. Winds were calm and skies clear. Two of the three early lights were red this time. Significantly, the SOC equalization point was considerably earlier, very near the second benchmark. Starting SOC was 54% (after another brief period of AC), so I adjusted for the 0.5% difference in starting SOC in defining the equalization point. Ending SOC again was 59%.
    Given the equalization point's location this time, I consider fuel economy results at the second benchmark most significant for this comparison: 70 MPG vs. 60 MPG. Not needing to stop for the third red light could account for a small part of the difference, but nowhere near 10 MPG.
    Here's the chart for the second EV run, along with a repeat of the non-EV chart. Pointers for the early stops are included; that and adjustment of the equalization point are the only changes to the non-EV chart.
  16. JimboK
    2,817
    190
    49
    Chesterfield, VA
    In response to a discussion in another thread, I put some math to this and came up with 0.72 hp. I averaged current and voltage (which the CV data stream also includes) for each set of runs. I multiplied them to figure wattage and then converted that to horsepower. Here are the individual numbers, with times, amp-hours, and watt-hours thrown in for good measure:
    Column 1 Column 2 Column 3 Column 4
    0 Per Run Averages N Glides PC Glides Difference
    1 Amps 1.260 3.638 2.378
    2 Seconds 100.5 90 10.50
    3 Hours 0.028 0.025 0.003
    4 Amp-hours 0.035 0.091 0.056
    5 Volts 226.6 225.3 1.3
    6 Watts 285.6 819.6 534.0
    7 Watt-hours 7.97 20.49 12.52
    8 Horsepower 0.38 1.10 0.72
    With these calculations comes an opportunity for error. Current and voltage readings are of course continuous, whereas CV’s data capture essentially does data sampling. And the sampling interval actually is slightly less than two seconds and seems to vary somewhat. I use two seconds (and state that they are approximate time intervals) for convenience and to keep the math simple.
    Is my process correct?
    (It sure would be nice if this forum had the code for building tables enabled! :()
    (EDIT: They do now, thanks to Danny's quick response to my suggesting it! :clap2:)
  17. JimboK
    2,817
    190
    49
    Chesterfield, VA
    A discussion on braking and regeneration in another thread got me to wondering about the relationship between brake pedal position and regeneration. These are data combined from most of my recent trips for which I have data:
    The CAN data stream captures brake pedal position on a scale of 0-127. (Why the odd number, I wonder?) Those data are converted to percentages for the chart.
    The data include all data points with any braking (brake pedal position of >0) and regeneration (current flow into the battery) at >7 MPH (to eliminate any effect of low-speed friction braking).
    Attila Vass has tested efficiency of regenerative braking using his own CAN monitoring setup. Based on current, voltage, and time to brake from 45 MPH to 5 MPH at various pedal pressures, he concluded that the most efficient braking occurs with a pedal position of 17 (13.4%). Interesting that, though the chart appears to demonstrate the expected relationship, current flow varies considerably at most positions represented -- including the 13-14% range. I figured the data points would be more tightly bunched.
  18. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    Thanks Jim. This somewhat helpful. I guess I'm not surprised at the spread since a given brake peddle position provides variable amounts of current back to the battery depending on the speed. Just looking at around 13.4% (which corresponds to Atilla's target peddle position of 17), it varies from about 8 to about 70 amps, with higher density (clustering) between about 10 and 40 amps. I have also seen references to 60 amp braking as being the most efficient. Does anyone have a source for that? Intuitively, it seems to make more sense to me to vary the peddle position in attempt to maintain a given amperage rather than keep a constant peddle position with variable amperage.
  19. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    I don't know how steady your foot is, but braking can often be a pretty rapidly varying process. Possibly the CAN-View sampling combined with the actual CAN bus reporting of the vehicle may not pair up pedal position and regen current from a perfectly corresponding moment.
    Another possibility may be that the car gives a strongly speed-dependent regen current at the same pedal position. In fact, I think that likely. If you expect to get similar deceleration at a given pedal position, then much more current is required at a higher speed.
    Would your CAN-View data allow you to do some form of filtering for speed? Possibly a first try might take the same pedal vs. current axes as above, but group points in 10 mph speed buckets by color or symbol. That should preserve enough points to see something if this particular suspicion has merit.
  20. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Given my continual focus on the car's operation and my awareness of the effect of even minor changes in pedal input (brake and accelerator) on the car's behavior and fuel economy, I'd say I have pretty good pedal control. ;) So my braking normally is pretty steady.
    I have considered the effect of speed. I thought about charting speed in some way in a variant of this chart but I didn't have time yesterday. And it will probably be a couple of days. I left the flash drive with my data plugged into another computer at another location, and I won't be able to retrieve it until tomorrow or the next day. :censored::frusty:
    Braking aside, I assume higher MG1 and MG2 RPM levels lead to higher amounts of regeneration. If that's the case, then the next challenge will be determining what portion of regeneration at any given speed can be attributed to braking. Maybe (when I get my hands back on my data) I'll chart regenerative coasting current.
