CAN-view problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by paulccullen, Sep 15, 2007.
  1. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    Hi all you CAN-view owners,
    My CAN-view (v3) had been workng perfectly until a couple of weeks ago. The first clue was when I enable EV mode, the MFD would no longer automatically switch to CAN-view mode like it used to. When I manually switch to CAN-view mode on the MFD it is essentially blank except for the buttons on the bottom, like this...
    [attachmentid=11473]
    And those buttons no longer do anything.
    I checked all the connections except the one at the back of the MFD (which is a pain to get to). But it looks to me like a software/firmware problem within the unit.
    Norm: Are you still around? I remember you saying you were no longer building CAN-view units a while back.
    Anyone else seen this, or have any ideas what's wrong?
    TIA,
    Paul.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Have you tried updating to the latest version or reflash it?
  3. paulccullen
    276
    Seattle, WA
    <div class='quotetop'>QUOTE(TheForce @ Sep 15 2007, 04:54 PM) [snapback]513151[/snapback]</div>
    Not yet, I thought about doing this, but don't have the necessary parts (external power supply, USB programmer and flashing software). I plan to get them.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    No DICE unit attached? Have you disconnected the power from the CANview and replugged it in?
  5. paulccullen
    276
    Seattle, WA
    <div class='quotetop'>QUOTE(efusco @ Sep 15 2007, 10:09 PM) [snapback]513214[/snapback]</div>
    Nope, no DICE unit. I'll try the power disconnnect. And I heard from Norm that the lastest V3 upgrades (CAN=SCsep067 and TV=SVjul097) should fix the problem
